| diyAudio Sponsor | ||
I am building a 6dj8-6as7 headphone amp, and it all working fine. This is my first scratch build project. So I have been doing a lot of SPICE sim and experimenting different things. Ragarding the PSU, I observed something interesting. The current draw is less than 60ma, power transformer is toroidal. AC heater supply comes from a separate toroidal heater transformer.
With Rectifier->45uf ASC Cap->10H-125ma Hammond 159P Choke->45uf ASC Cap I hear loud hum noise. With Rectifier->470uf electrolyptic Cap->10H-125ma Hammond 159P Choke->470uf electrolyptic Cap I hear no hum at low volume. The SPICE sim result shows that 10H/45uf PI filter should give low enough ripple. Not having an o-scope to do more test, I can only suspect the Hammond choke might be the cause of hum. Anyone has similar experience? |
#2 |
When you exchange that last cap, I guess because of the different form factor, you also change the ground connection of that cap to a different one.
Very often these things are a result of ground loops. If you indeed change the connection, try to connect the caps both (when changing) exactly to the same point, and see if it still makes a difference in hum. Possibly not, and then you know the correct connection. Jan Didden
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#3 | |
Beware to hight voltage! |
#4 |
Hi pftrvlr ,
First of all , your headphone amp is drawing less than 60 mA , from the power supply , your choke is rated for 10 H @ 125 mA , so it is not developing the total self-in- ductance , then the SPICE sim , does not reflect the actual situation . Second , as a rule of thumb , the capacitor value have to be aprox. 2200 uf / Ampere , to give you a low ripple . In your case , 2200 uf x 0.060 A = 150 uf . Third , to give you a “perfect” capacitor behavior , you need to connect in parallel with each electrolytic cap , a mylar or a polypropilene cap , with 1 / 100 of its value . Say , if you are using a 150 uf elec. cap , you have to use a 1.5 uf in parallel with it , and the best solution , another plastic capacitor of 1.5 uf / 100 = 15 nf , in parallel with the others . ( total 3 capacitors in parallel , 150 uf + 1.5 uf + 15 nf ) The new filter will be : 150 uf + 1.5 uf + 15 nf --> Choke --> 150 uf + 1.5 uf + 15 nf Obviously I am assuming that you are using solid state rectifiers , so the input capacitor value will not be a problem . Try this solution , and give us a feedback , Regards , Carlos |
#5 |
Carlos: The choke's inductance might be a little low from drawing 60mA rather than 125mA, but nothing much to worry about. I think you may be coming from a solid-state viewpoint with your capacitor rule of thumb - valve rectifiers won't tolerate much capacitance. Adding small values of capacitance in parallel with an electrolytic will tidy up HF behaviour, but not change hum.
Pftrvir: I think the problem is more likely to be that headphones are very sensitive transducers so the acceptable levels of hum are much lower. It could always be a wiring problem as Jan has suggested, in which case the hum is likely to have a buzzy sound, but it may simply be that you need to add another stage of filtering. If you're keen and competent with SPICE, then why not calculate the level of hum that would be 120dB down on the headphone's maximum output and see if your amplifier sims at that level?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#6 |
Thanks everyone.
The PSU has both a solid FRED rectifier and a 5Y3 tube rectifier. I can swith between this two easily depending the output voltage I need. Immediately after the rectifier is a 50 ohm resistor. I'm too concern about the in-rush current of the 5Y3. I do parrallel a 1.5uf MKP cap with the electrolyptic cap. Having too many of the 1.5uf MKP, I put them everywhere. Wiil do more SPICE and DMM work and report what I find out. Also thinking to get a cheap o-scope from EBay. |
#7 |
If your using your PC as a source it is a grounded signal supply. If you have your preamp grounded as well the hum is probably caused by a system level ground-loop.
SoCal hu? Do you live near Santa Clarita by any chance? |
#8 |
Is the filament supply floating? Connect a 1.uf cap from one side to ground.
#9 | |
SPICE capacitor don't have tolerance and parasitic component. The real inductor is a non linear component with a serie resistor also the conductors have a small resistance. In many cases these parts can be neglected in others they become remarkable. |
#10 | |
When I test the amp hum, the amp is either connected to an Oppo 970 player or nothing. I thought about the ground-loop/pin-1 issue, but it does not look like it is case. |
| Noisy ADC | 5th element | Digital Line Level | 6 | 30th August 2009 11:29 PM |
| Noisy NAD 705 | squirrel69 | Solid State | 6 | 7th April 2006 02:37 AM |
| noisy noisy noisy noisy noisy tube | dsavitsk | Tubes / Valves | 50 | 20th February 2006 05:07 PM |
| help on P1.7 (Noisy) | pamaz | Pass Labs | 9 | 26th August 2004 03:21 PM |
| How can i use a noisy PSU ? | Garbz | Solid State | 5 | 3rd January 2004 01:15 AM |
| Page generated in 1.30085 seconds (12.62% PHP - 87.38% MySQL) with 10 queries |
