#11 |
SY,
No fine then. I was too lazy to calculate! I will compare this some time with my transistor job. Thanks. Ilimzn, Ray was commenting on the contents of that article that was quoted - not necessarily to do with our subject. Regarding the non-linearities you mention, one normally tries to keep their effects out of the audio band. In that way you can get some < [0.1 - 0.05]% non-linear distortion out of a transistor front-end with good design and some local feedback. You will be hard put to get that with tubes. But since one can have inaudible distortion with both technologies, the question does arise, why the extra bother with tube power supplies etc. For me it will be a consideration of convenience, not really a substantial difference in performance. |
#12 |
diyAudio Moderator Emeritus
Sy,
I was thinking of both noise and microphony. (Anyway, enough from me on this. As Johan says, we should probably stay on topic - or start a new thread!) |
#13 |
Sy,
I was thinking of both noise and microphony. (Anyway, enough from me on this - as Johan says, we should probably stay on topic.) |
#14 |
So I am reviving this thread because I started thinking about using a semisouth jfet to drive a 300b. That is a bit cost prohibitive for me to experiment with personally but I am curious if there are any amps people have personally built that have a SS front end and tube output? If so how did it sound? If not, do you think this can be done while being directly coupled to the output tube? I like the idea of having no caps, or only one cap in the audio signal path.
#15 | ||
For music reproduction, I would prefer hollow state up front, and a couple of power MOSFETs (or those SiC JFETs, if they ever become something other than unobtanium for anyone who's not in the market to buy hundreds at a time, that is) on the back end. |
| Swap Shanling CD-T80 valve CD player for Quad valve equiment | johnm | Swap Meet | 2 | 24th September 2009 12:15 PM |
| what powersupply to use for this poweramp soild state | prorms | Power Supplies | 1 | 31st October 2006 06:07 PM |
| Convert a non-valve amp to a Valve (tube) Amp | seanthomas46 | Tubes / Valves | 11 | 6th September 2005 09:52 PM |
| searching software to switch front speakers to rear and rear to front!-dolby surround | MCM | Everything Else | 6 | 6th February 2004 09:29 PM |
| Oil Filled Transformers Valve Filaments or Solid State Equipment | mozfet | Swap Meet | 2 | 28th October 2002 07:22 PM |
