HV Valve Shunt reg.
HV Valve Shunt reg.
Old 29th January 2003, 04:04 PM   #11
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
James,
I'm sure it would be a tragedy for anyone to miss the "sripping housewives" Do they now have mpeg artifacts? what's their bitrate?
Old 30th January 2003, 12:32 PM   #12
James D. is offline James D.  United Kingdom
Still too busy at work No stripping housewives either
Thanks for all the input. John's application was the origional inspiration for my thoughts but I have a pair of 845's myself so one day I will need this too.
The STV280 regulator is a nice design that yields four stabilised voltages out at 280V, 210V, 140V and 70V from one tube - four anodes - useful for some apps. and it's still relatively cheap at about 18 euro.
When I get time I'll rework redraw the design incorporating your suggestions to produce a design that might actually work!
ciao
James
Old 31st January 2003, 11:34 AM   #13
dhaen's Avatar
Whilst I realise that this thread is not solely for my benefit, some posts have been aimed at a solution for my HV problems.
So thanks to all for their input on this thread.
I have given shunt regulators some consideration, but have decided to re-invesigate high voltage series regulators.
I may open an HV Valve Series req thread shortly.
Old 31st January 2003, 07:52 PM   #14
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default VR280 ANYONE?
I thought you all deserve a piccie of the STV280.
Two versions exist,one at 40mA and the bigger brother is good for 80mA.
This is the bigger one:
Frank
Old 31st January 2003, 08:29 PM   #15
fdegrove's Avatar
Default EL509
I'll agree that an EL519 would work fine.
If you want to stick with octal types the KT90 would do the job too and you get rid of that anode cap too.
For the curious:
Frank
HV Valve Shunt reg.Hide this!Advertise here!
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 04:11 AM
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 45 5th July 2013 10:50 PM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 12:15 PM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 09:47 PM
