| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Tubes / Valves All about our sweet vacuum tubes :) |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
hi all,
has anyone tried before? can it be done? thanks for input.. rgds, tone |
#2 |
diyAudio Moderator Emeritus
Tone,
There are a number of problems: They cannot accept any DC, so push pull is essential. There is barely enough inductance. The interwinding capacitance is not controlled, so different makes with the same ratings will give different results. I think 316a has done some work with them. Hopefully he'll reply. Cheers,
John _____________________ Diy site: http://homepage.mac.com/dhaen/OnRyoku/OnRyoku.html Trading site: http://www.keystrobe.com |
#3 |
hi dhaen,
can a cap at primary winding do the dc job? |
#4 |
I know some PP amps have been built with Talema toroids. There is a lot of variation in terms of primary inductance; some toroids are quite high.
#5 |
If u use a parafeed type arrangement you can use toroids..I believe a 50va toroid with a 10:1 stepdown will work..so something like 230v-25volts...
The CCS can be something as simple as a resistor. Just add a cap in one leg of the primary and voila! But yes hopefully 316a can shed some more light on the subject. |
#6 | |
Tone,
![]() Then the primaries could be put in series. Tiroth, So desu ka? I was just wondering whether the smaller ones would have enough inductance. He wouldn't want a 50VA thing in his preamp. ![]() Ja mata. Of course both ideas depend on the transformer being fed from a sufficiently low source impedance. I wonder if it worth the trouble. How much does a run - of - the - mill audio stepdown transformer cost in that part of the world? Kampai,
#7 |
#8 |
wiligruen,
That's elegant. ![]() And a tiny transformer too! Cheers,
#9 |
dhaen,
Ee. As luck would have it I have a tiny 1.6VA 2:1 toroid (70000 series) and a larger 35VA 27:1 (62000 series) arriving Thursday. I'll measure the primary inductance and report back. |
#10 |
Tone:
Major dumb question: what are you trying to accomplish? I've always found it useful to define a problem before trying to evaluate solutions. |
| Thread Tools | |
| Tube Mic Preamp - which Edcor transformer? | pftrvlr | Tubes / Valves | 6 | 19th April 2009 07:43 PM |
| Output Tube biasing for Toroidal Output Transformer | gingertube | Tubes / Valves | 7 | 17th April 2005 05:40 PM |
| preamp gain and output transformer question | vlljpior | Tubes / Valves | 2 | 18th January 2005 08:05 PM |
| passive preamp with transformer output - which parts to use? | krishu | Parts | 9 | 1st June 2004 05:33 PM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 09:57 AM |
| Page generated in 0.41350293 seconds (42.81% PHP - 57.19% MySQL) with 10 queries |
