| diyAudio Sponsor | ||
#11 |
Tone,
Toroids will work but the end result will very much depend on the quality of the core. So the final sound especially the highs is very much of a touch and go thing. If you actually have the winding details(no of turns, layers etc), I know a guy in KL with Z11 grade core which will be adequate for OPTs and the price is very reasonable. If you want to be sure, try Martin Electronics in Bencoolen Square in S'pore. He sells Lundahls at a price of about USD75 each. Regards, ckt |
#12 |
nothing wrong with using toroids . Points to remember are to keep the DC well away from them and avoid saturation . I don't know about pre-amp usage but I've been using them as power amp outputs for the last year . Primary inductance is usually high but finding large enough sizes with the correct turns ratio can be tricky , this means that for power stages you need to drive with Low Ra valves . The main problem is the core size , when pushed hard the bass can fall apart but I doubt this should be a problem with pre-amp usage . Try them , they should work well for pre-amps . Best application to date for me is parallel feed , push pull is another possibility but you'll need to take into account balancing the output stage , keeping the HT low . Remember these things weren't designed to swing 400v p-p across them at 20Hz .
316a |
#13 |
As promised:
1.6VA as line input ============== 2:1 Primary inductance: 4.5H Primary interwinding capacitance: 200pF with 13k secondary load -0.5dB at 20Hz -0.3dB at 20kHz The bad news is that distortion is on the order of 0.6% at 20Hz, -0.05% at 250Hz, 0.001% at 500Hz, and unmeasurable at higher frequencies. This would be excellant as line input for a tweeter amp, but the primary inductance just doesn't appear to be high enough for the low frequencies. 35VA as OPT ========= 27:1 Primary inductance: 146H Primary leakage inductance: 10.5mH Primary interwinding capacitance: 1.4nF Not bad! |
#14 |
with my very basic primary inductance testing I usually get 100H for a 50VA 230V:6-0,6-0 unit at 50Hz . This is more or less the largest size with the highest turns ratio . Sizes above that such as 230:9-0,9-0 etc require the output valves to be 6C41/6C33 type things . I am also tempted to unwind the secondary windings and use as a push pull anode choke . Anyone ever thought of doing this ?
316a |
#15 |
diyAudio Moderator Emeritus
316a,
How about using a CCS on one side, and then you can use the other side SE. ![]() Nice for a driver anode choke? You could even put a teeny amount of current feedback to the cathode from the 6v winding. This is of course "pub talk"... Cheers, |
#16 |
rgds,
tone |
| Tube Mic Preamp - which Edcor transformer? | pftrvlr | Tubes / Valves | 6 | 19th April 2009 07:43 PM |
| Output Tube biasing for Toroidal Output Transformer | gingertube | Tubes / Valves | 7 | 17th April 2005 05:40 PM |
| preamp gain and output transformer question | vlljpior | Tubes / Valves | 2 | 18th January 2005 08:05 PM |
| passive preamp with transformer output - which parts to use? | krishu | Parts | 9 | 1st June 2004 05:33 PM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 09:57 AM |
| Page generated in 0.09742 seconds (76.98% PHP - 23.02% MySQL) with 10 queries |
