| diyAudio Sponsor | ||
#11 |
Yves,
It is a typo indeed, the core area is 25 cm2. You have a good point about the Vg2 swing. What do you suggest then? Laszlo |
#12 |
You will have to go down in turns no for the screen winding. This will result in a UL connection but still with separate B+. This should be good for quite some power since you could run the plates at 600V while still keeping the screens below 300.
I know this has been made but i don't seem to find any references right now. Yo probably have to check the maths to see if screen dissipation is still safe and if the usual approx 40% turns ratio for UL still holds with different voltages on plate and screen.
I'm not allowed to do magic, union rules... |
#13 | |
Freq Response at -2 dB (Single Ended 6123HS) 18Hz~67Khz @ 2.5K 18Hz~64Khz @ 3.5K 18Hz~53Khz @ 5K So can one say that "low Z wins in frequency response and power, but loses in distortion"? |
#14 |
The reason could be the higher capacity of the high-Z primary winding.
| Help with an amp, turns on but no sound | HeavyD'sCustom | Car Audio | 40 | 5th May 2009 03:36 PM |
| Precision Power PC6600.2 Amp turns on then immediately turns off. Need help! | autolink | Car Audio | 4 | 15th March 2009 02:12 AM |
| McIntosh transformer turns ratio | SpreadSpectrum | Tubes / Valves | 8 | 27th December 2008 09:50 PM |
| electrostatic transformer turns ratio | willyhoho | Parts | 1 | 1st April 2006 04:46 AM |
| Which turns you on? | nl | Digital Source | 0 | 30th July 2004 10:50 PM |
| Page generated in 0.08089 seconds (75.60% PHP - 24.40% MySQL) with 10 queries |
