| diyAudio Sponsor | ||
I was looking at Thorsten's site and he uses these on the power supply.
I know that lundahl has them on its catalog. Do these function similar to a "normal" power supply choke? Thank you. |
#2 |
The common mode choke is a "bifilar" or balun type choke at the input of the power line....
There is winding in the feed and return line and the net DC flux in the core is zero due to the way the windings traverse.... It is used to meet certain EMI requirements or audio susceptibility requirements.... It is used in conjunction witrh Y-caps... for a -40db/Decade slope double Pole filter.... Chris |
#3 | |
http://www.fortunecity.com/rivendell...dison300B.html |
#4 | ||
#5 |
Gerrit,
If I have a common mode choke, can I connect the two coils in series using it a a simple/single line choke? If so, does it halve the allowed current? Jan Didden
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#6 |
I've been studying this concept for some time and in more detail recently.
My question is how would one model this 20H Lundahl CMC in PSUDII? |
#7 |
Hi Jan,
According to the LL1673 specsheet the two chokes are in series when you use it as a common mode choke, it's just that the two chokes are not 'in the same leg'. So if you use it as a normal serial choke, the inductance and rated current stay the same. As for modelling in PSUDII, use the values for a serial connection. LL1673 specifications and connections |
| Common-mode EI PS Chokes | rdf | Tubes / Valves | 14 | 17th June 2007 09:36 AM |
| Common Mode Chokes for Heater Supplies | ppereira | Tubes / Valves | 7 | 29th January 2006 02:45 PM |
| Source for common mode chokes | abj1 | Tubes / Valves | 7 | 24th June 2005 07:31 AM |
| Using common mode chokes in filament supply. | G | Tubes / Valves | 8 | 9th December 2002 04:10 PM |
| Common mode chokes | Dr.H | Digital Source | 1 | 24th July 2002 05:47 PM |
| Page generated in 0.09734 seconds (77.15% PHP - 22.85% MySQL) with 10 queries |
