| diyAudio Sponsor | ||
I recently posted the following on the HH Scott forum. Unfortunately I only received one response. Any thoughts from the diy Audio crowd would sure be appreciated!
With the help of several kind folks on this and other forums (Thank you!), I recently finished rebuilding a 299A (later type). It has a non stock output transformer on one channel that is noticeably smaller than the original, and not surprisingly that channel doesn't sound as good. I also have 2 other amps that I haven't touched. One is a Heathkit AA-151, the other is a Dynaco SCA-35. Should I cannibalize one of these to improve the 299? Would the other transformers even work in the 299? Or- is there a source for 299 output transformers? Mike |
#2 |
Assuming they will fit, I'd use the trafos in the AA-151 to fix the 299A up. That selection is based on the presence of 16, 8, and 4 Ohm speaker taps. You have the choice of tieing the UL taps off or experimenting with them.
Sell the Scott OEM trafo on Flea Pay. The AA-151 power trafo is a candidate for use in an "El Cheapo" variant. You'd SS rectify the B+ and voltage multiply the 5 VAC winding to get the B- rail. I haven't the foggiest notion where a single Scott OEM trafo can be sourced.
Eli D. |
#3 |
Actually the A is the earliest incarnation of the 299 which ran from A to D. The A and B version transformers might interchange, but I cannot attest to that. (They both use 7189A unlike the later C & D which use 7591 output tubes)
You might have some luck looking for another A on fleabay. I had one unfortunately with a blown power transformer and traded it for some parts a few years ago, you might get lucky and find one if you are persistent enough.
www.kta-hifi.net |
#4 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
According to the HH Scott site, the LK-48 uses an 8-5 series OPT and the late 299A's used an 8-4.
Is there a significant difference? |
#6 |
frugal-phile(tm)
I don't know... the amp came with 7189s ...
dave
#7 |
Planet 10,
Do you have any interest in selling your OPT's? |
#8 |
frugal-phile(tm)
I don't know... they are awefully good OPTs, and the other amp we have using them is soooo good, but probably for the right price. I'll have to consult Chris.
dave (how's that for waffling?)
#9 |
The waffling is understandable.If you don't want to part with them, I can always try the AA-151 OPT's.
#10 |
frugal-phile(tm)
OK, we'll let them go... mail me and we can negotiate a price...
dave
| Late Hi | RCruz | Introductions | 6 | 25th November 2008 12:10 PM |
| Late introduction | argonrepublic | Introductions | 14 | 26th January 2006 01:41 AM |
| Better late than never... | rjon17469 | Introductions | 2 | 22nd August 2005 03:01 PM |
| Better late than never... | purplepeople | Introductions | 5 | 6th August 2003 11:21 PM |
| Late introduction. | jwv3 | Introductions | 0 | 8th March 2002 04:07 PM |
| Page generated in 0.09557 seconds (80.75% PHP - 19.25% MySQL) with 10 queries |
