diyAudio Sponsor
Old 27th June 2007, 12:35 AM   #1
podboy is offline podboy  United States
Default EL-34 and 100k pot
I recently purchased a Sophia Electric EL-34 amp and paired with a Paradisea DAC. My problem is that there is to much gain. At 9 o'clock it is beyond a comfortable listening level for the room. At low volumes the L+R balance is off. The volume pot is currently a 100K Alps blue. How would a 50k or 250k pot affect the volume control? I would like to do most of my listening in the 9-1 o'clock range. Will it affect the sound? Thanks
Old 27th June 2007, 12:49 AM   #2
Changing the value of the volume pot. will not provide relief from the "hair trigger" problem.
Assuming the source is capable of driving a "10" KOhm load, the solution is to build resistive voltage dividers inside the RCA plugs that insert into the amp. Use 1/8 W. 1% tolerance metal film parts. 6.8 KOhm resistors are inserted in the lines that go to the center/"hot" terminals of the plugs. 3.3 KOhm resistors bridge the center/"hot" and outer/"cold" connections. The values given yield approx. 9.7 dB. of attenuation.
Eli D.
=>$100k Amplifiers !!! Bonsai Solid State 19 29th November 2008 04:39 PM
100K pot in a preamp? G Tubes / Valves 5 15th May 2008 03:41 PM
Noble 100K pot. mattjk Swap Meet 0 21st January 2008 03:50 AM
50K vs 100K POT ss1 Parts 7 22nd July 2004 01:57 PM
50K or 100K pot? 2Bak Chip Amps 14 9th November 2003 03:25 AM
Page generated in 0.06391 seconds (72.21% PHP - 27.79% MySQL) with 10 queries
