diyAudio Sponsor
Old 24th June 2007, 10:40 AM   #1
jarthel is offline jarthel  Australia
Default DHT output tubes and DC heating
Can I:
1. connect their heaters in parallel?
2. same as no. 1 but in series
3. I guess that if nos. 1 and 2 aren't possible, does that mean I must have a separate winding for each tube?
Thank you very much
Old 24th June 2007, 01:30 PM   #2
i_should_coco's Avatar
Is this SE or PP? Output tubes or...?
For SE, you will need a separate winding for each channel and each stage.
For PP it is ok to parallel up the heaters of the tubes in a PP pair.
Old 24th June 2007, 02:43 PM   #3
tubelab.com's Avatar
This is possible. You can connect the heaters in parallel even in a SE amp, if one side of the heaters is grounded. This requires fixed bias, and some other means to monitor plate current. I use a 10 ohm resistor in series with the plate. I use one filament winding, rectifier, filter, and regulator chip to power both channels.
It is also possible on a push pull amp if both tubes share a common cathode resistor. A seperate winding for each channel would be required.
I have seen (in a name brand amp) one filament winding powering the heaters in both channels of a SE amp. The two channels shared a common cathode resistor and relied on a big electrolytic bypass cap for channel separation. Not what I would call optimum.
Wiring the two heaters in series would guarantee a different bias level for each tube. This could be compensated for with fixed bias, but again not optimum.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 24th June 2007, 08:11 PM   #4
One thing to bear in mind is whether you are likely to pull one tube out when you run two tubes off one DC supply. If you do then you will find the following:
2 tubes in series, voltage regulation - OK - remaining tube does not light since circuit is broken
2 tubes in parallel, voltage regulation - OK - remaining tube gets same voltage
2 tubes in series, current regulation - OK - remaining tube does not light since circuit is broken
2 tubes in parallel, current regulation - NO!!! - remaining tube gets double the current!
Old 24th June 2007, 11:15 PM   #5
so what is the recommended solution?
separate heaters for each output tubes?
for example in push-pull: Can I construct 2x DC supply out 1 secondary for each channel? Is this okay?
Thanks again
TV Horz. Output Tubes used as Output Audio ppl Tubes / Valves 90 27th August 2009 02:21 PM
Compactron Output Tubes audiowize Tubes / Valves 10 18th June 2008 01:38 AM
Which of these output tubes? jnb Tubes / Valves 1 21st June 2007 03:49 PM
DC heating directly heated output valves mikeyyy Tubes / Valves 5 20th September 2006 02:00 PM
Any other sub for KT 88 output tubes? Original Burnedfingers Tubes / Valves 13 22nd January 2005 10:28 PM
Page generated in 0.07892 seconds (76.52% PHP - 23.48% MySQL) with 10 queries
