CCS turning off prematurely?
Old 23rd June 2007, 03:50 AM   #1
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Default CCS turning off premature
One of my amps has a stage with a CCS loaded 12ax7 and it seems to be clipping about 25 volts before it hits the supply rail. Is it possible the transistor is turning off due to lack of current?
Old 23rd June 2007, 05:23 AM   #2
On Hiatus
SY's Avatar
Could be, could be something else (even a measurement error is possible at these impedances). A schematic would help.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 23rd June 2007, 06:41 AM   #3
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Re: CCS turning off premature
Originally posted by Jeb-D.
One of my amps has a stage with a CCS loaded 12AX7 and it seems to be clipping about 25 volts before it hits the supply rail.
Or to put it another way, the CCS allows the 12AX7 to swing its anode to within 25V of the HT. That's pretty good.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
CCS turning off prematurely?Hide this!Advertise here!
Pop from amp when turning off speed3 Tubes / Valves 2 25th September 2007 05:59 PM
Are there any way of turning DC to AC jacquesl Power Supplies 32 2nd March 2007 10:40 PM
Turning a car amp into a pc amp JDAudio Solid State 3 16th September 2004 06:10 PM
Turning Pro griff Everything Else 33 3rd October 2002 10:31 AM
Copyright ©1999-2017 diyAudio
