diyAudio Sponsor
Old 20th June 2007, 06:51 PM   #1
Klimon is offline Klimon  Belgium
Default Simple cathode CCS
Any suggestions for a component for ultra-cheap and simple cathode CCS? Current draw is 25mA, ca. 15V per tube.
LM317 is easy obtainable here (my local electronics store can supply all Farnell-parts), stuff like 10M45 or DN2540 unfortunately not...
Diyaudio / Gary Pimm / Machmat CCS are probably better but I'ld like to start cheap and easy... If Farnell has alternatives for Lm317 I'ld be interested to know
Simon
Old 20th June 2007, 11:21 PM   #2
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Did you have a look at diyAudio's CCS? Darn cheap!! And works great.
Old 20th June 2007, 11:53 PM   #3
jnb is offline jnb  Australia
Would you have a link please, searching with the keyword 'diyaudio' isn't easy
Old 21st June 2007, 12:28 AM   #4
I have the PDF manual that planet10 (dave) sent me. fire me an email and I'll reply back with it.
Old 21st June 2007, 07:51 PM   #5
Shoog's Avatar
The LM317 works very well in this application.
Shoog
Old 21st June 2007, 08:26 PM   #6
Arnold, I sent you a PM for info on the diyaudio ccs.
Shoog, I'll probably end up using LM317 for this project, it's noted.
Thanks,
Simon
Old 21st June 2007, 09:10 PM   #7
Are these DIYaudio CCS boards still available? If so, who is selling them? Please let me know, you can PM me if you prefer.
Thanks, Daniel
Old 21st June 2007, 09:33 PM   #8
To help Arnoldc in case many want this pdf, I will also send it if you pm me.
Old 21st June 2007, 10:07 PM   #9
SY's Avatar
Thanks, Daniel
Check with Planet 10 to see if he stll has any left. If not, drop me a note and I'll fix you up.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 22nd June 2007, 05:31 AM   #10
mus is offline mus  Canada
Hi Shoog,
Does the LM317 CCS need the cathode bypass capacitor? Actually I don't like any bypass cap at all! Thanks.
simple se cathode resistor question pforeman Tubes / Valves 4 1st June 2009 05:08 PM
Simple SE cathode feedback... oldmanStrat Tubelab 9 1st May 2009 07:51 PM
Cathode feedback on the simple SE ixe13 Tubes / Valves 0 23rd April 2009 11:52 PM
simple 12AU7 cathode follower Southside Ron Tubes / Valves 18 1st April 2007 04:02 PM
Problems With Simple Gounded Cathode Gain Stage dr._sleep Tubes / Valves 4 23rd January 2006 08:31 PM
Page generated in 0.09372 seconds (79.49% PHP - 20.51% MySQL) with 10 queries
