| diyAudio Sponsor | ||
Here is a simple C-RC-RC 5vdc power supply for a 300b filament.
(see attachment) I would like to use the 6.3vac 6A from T1, which would be about 7vac at 1.3A. According to the Power Supply Designer II s/w there will be 3mv p-p ripple. Is 3mv of ripple low enough? Do you recommend a filament choke? Thanks |
#2 |
3mV of ripple is better than 5V
#3 | |
You can find my story here: Heater supply John Atwood also performed some research on this topic: DC filament supply test |
#4 |
Gerrit, Thanks for that info.
So the choke is the way to go if you have the room for it and a few more $. According to PUS Designer II s/w, a RC-RC has about the same ripple voltage as a LC filter. For my PUS Designer II comparison I used: C-RC-RC 10,000uf - 1R - 10,000uf - 1R - 10,000uf Vrs C-LC 10,000uf - 60mH – 10,000uf It would be interesting to see how the RC-RC filter looks on the Audio Precsion System 2 that John Atwood used on his test. |
#5 | |
I suggest comparing in PSUD not only the output, but take a look at the input waveforms. True rms values will be different, due to the harmonics. Also compare ripple current requirements for the capacitors; they will be very different. Lower ripple current results in longer life for an electrolytic capacitor. Fewer high order harmonics makes for less noise. Aside of cost and weight, there are only good things to be had with choke filters. |
| Simple heater question | athos56 | Tubes / Valves | 4 | 27th May 2009 05:31 PM |
| 5687 filament heater question | dr._sleep | Tubes / Valves | 2 | 25th August 2005 03:45 AM |
| Heater Question | lpd | Tubes / Valves | 4 | 20th February 2005 05:35 PM |
| DHT DC heater question | etalon90 | Tubes / Valves | 5 | 1st January 2005 09:34 PM |
| Heater winding load question. | G | Tubes / Valves | 3 | 22nd May 2004 06:40 PM |
| Page generated in 0.10233 seconds (77.38% PHP - 22.62% MySQL) with 11 queries |
