diyAudio Sponsor
Old 20th June 2007, 02:33 AM   #1
jnb is offline jnb  Australia
Default Which of these output tubes?
For a tweeter, would you choose a 45 or a KT66?
For a woofer, would you choose a KT66 or a 6550?
All single ended, power output not an issue.
Old 21st June 2007, 03:49 PM   #2
kevinkr's Avatar
I think it depends mainly on how much output power you require.
The 45 in SE is good for no more than 2W, the KT66 probably around 5W - 6W, and the 6550 perhaps 7W - 10W in triode connection.
Another option for the tweeter amplifier would be the 2A3 which could get you to 3.5W output.
www.kta-hifi.net
TV Horz. Output Tubes used as Output Audio ppl Tubes / Valves 90 27th August 2009 02:21 PM
adding output tubes etc to pre amp pforeman Tubes / Valves 1 2nd February 2009 06:02 PM
output tubes for stereo 70 Original Burnedfingers Tubes / Valves 7 9th February 2008 12:13 PM
Any other sub for KT 88 output tubes? Original Burnedfingers Tubes / Valves 13 22nd January 2005 10:28 PM
Transcendent T8 with 12 output tubes ackcheng Tubes / Valves 1 24th November 2004 03:42 AM
Page generated in 0.05596 seconds (68.78% PHP - 31.22% MySQL) with 10 queries
