diyAudio Sponsor
Old 28th January 2012, 09:06 PM   #11
DF96 is offline DF96  England
21mA is a bit high for an ECC83!
Old 31st January 2012, 11:15 PM   #12
does the formula only work with ecc83. example numbers are for a 5881 tube. but any sample numbers would be fine.
update: in reading furthur it turns out that there is no simple formula. you need to do vertical and horizontal plots. I was looking for a simple formula to check the accuracy of my tube tester. It would be nice to be able to use a bias probe to get current and then measure plate voltage...put the numbers in the formula and compare to the meter reading. I do have a calibrated calibration tube, but it only works in the 1000 to 4000 range. I want to see if I have nay transformer sage when testing high power octals.
nVidia CUDA GPU computing PC FIR KOON3876 Digital Line Level 66 30th May 2011 10:40 PM
Tube Tester Resto Basics Steven-H Tubes / Valves 17 8th January 2010 12:10 AM
Hi, looking for some info on tube amplifier design basics rockgardenlove Tubes / Valves 5 22nd October 2008 12:57 AM
good book for learning the basics of tubes and tube amps frajavcar Tubes / Valves 5 18th July 2008 07:33 PM
Page generated in 0.06387 seconds (66.82% PHP - 33.18% MySQL) with 10 queries
