Good Souinding Direct Replacement For 325 / OP 37 Good Souinding Direct Replacement For 325 / OP 37 - diyAudio
Old 19th June 2007, 06:48 AM   #1
XTRprof is offline XTRprof  Singapore
Default Good Souinding Direct Replacement For 325 / OP 37
Hi all,
I'm new to this. I have a Jolida JD9. What's the best sounding direct replacement OPAs for the op amp 325 / OP 37 in the jolida? Will the OPA 627 or 637 be better?
Thanks.
Old 19th June 2007, 12:09 PM   #2
ilimzn is offline ilimzn  Croatia
Wrong forum?
Good Souinding Direct Replacement For 325 / OP 37Hide this!Advertise here!
quad 303 pcb -- direct replacement / modification bigpanda Swap Meet 5 9th June 2016 09:49 PM
Direct (or almost direct) replacement for Morel MW144? mr_push_pull Multi-Way 1 19th April 2009 04:43 PM
Better Sounding Direct Replacement For OPA OP37 In Jolida JD9 Phono Stage XTRprof Analogue Source 5 30th June 2007 10:00 AM
good tempest replacement? saramac Subwoofers 9 12th December 2005 02:57 AM
OnSemi MJL3281A/1302A direct replacement for SK 2SC3856/2SA1492 ? JohnSz Solid State 15 24th November 2005 10:29 PM
Copyright 1999-2017 diyAudio
