diyAudio Sponsor
Old 18th June 2007, 02:54 PM   #1
dieselpower's Avatar
Default Advice/Help - Cap upgrade
Hey guys, I bought a Counterpoint SA7 preamp a few months back, and would like to upgrade/replace the caps throughout as they are 20+ years old. Where do I start? all caps at once or a few at a time.
I would like to keep prices below $150, but am having difficulty finding the higher voltage caps for the tube section (100uf/350v & 47uf/450v) other that some very high priced Blackgates.
Also recommendations for the PSU caps, and phono/line stage caps - which are currently Relcaps.
PSU (is the large cap 47uf/450v part of PSU or tube section???)
http://home.comcast.net/~brett_mayer.../image028a.jpg
Tube caps
http://home.comcast.net/~brett_mayer...s/image026.jpg
RelCaps
http://home.comcast.net/~brett_mayer.../image022a.JPG
thanks for any help
Brett
Old 18th June 2007, 04:27 PM   #2
SY's Avatar
105 degree rated Chemicons at the required voltage and capacitance are available from Digikey or Mouser. They're pretty inexpensive and work very well.
For coupling caps, you'll hit the law of diminishing returns once you use some decently constructed polypropylenes. Your old caps may still be just fine, probably are, but if any have gone leaky or drifted off value, Wima FKPs are as good as anything else out there, except for their lack of fashion and prestige value and their reasonable pricing.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 18th June 2007, 05:03 PM   #3
Default Re: Advice/Help - Cap upgrade
(SNIP)
thanks for any help
Brett
Brett,
I tried to send you an email and found I couldn't, but if you want you can contact me and I'll help you out.
Old 18th June 2007, 06:13 PM   #4
Jim
thanks for your assistance! I tried to email you also & found that it is disabled. you can email me at brett.mayer00 (at) gmail.com
thanks
Old 18th June 2007, 10:53 PM   #5
Sir Trefor's Avatar
I replaced all of the coupling caps in my HH Scott with Orange Drop(polypro) capacitors a few years back and noticed a marked improvment. Available on Antique Audio Supply- http://www.tubesandmore.com/. Pretty decent price for the quality
"This is just my 'one cent'; I haven't got two to give."
Old 18th June 2007, 11:44 PM   #6
mach1 is offline mach1  Australia
mach1's Avatar
Panasonic TSHA and TSHB are both excellent.
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman
Old 19th June 2007, 01:23 AM   #7
Jim
thanks
You have mail!
Big upgrade of Neptune 820! Need some advice... rice'n'beans Solid State 1 1st April 2009 11:03 PM
LM3886 based Amp -Upgrade advice please. mikesnowdon Chip Amps 3 26th October 2008 12:53 PM
Speaker Upgrade Advice Please Friends quasi Multi-Way 2 4th May 2007 03:35 AM
2 way speaker kit upgrade advice mark0311 Multi-Way 3 9th June 2005 10:46 PM
CD upgrade advice ultrachrome Digital Source 3 6th May 2004 05:14 PM
Page generated in 0.09982 seconds (82.83% PHP - 17.17% MySQL) with 10 queries
