diyAudio Sponsor
Old 18th June 2007, 01:44 AM   #1
Default Preamp Power and Voltage Output
How much voltage and current should a preamp output?
thanks
Old 18th June 2007, 04:23 AM   #2
frugal-phile(tm)
planet10's Avatar
Default Re: Preamp Power and Voltage Output
Depends on what you are driving... typically 2-20 V
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th June 2007, 07:23 AM   #3
diyAudio Moderator Emeritus
ray_moth's Avatar
Your question can't really be answered without more information. As planet10 says, it depends on what you're planning to drive.
Current and power outputs don't enter into it - it's all about output voltage and impedance. The important things to know are the amp's input sensitivity (in millivolts RMS) and its input impedance. A typical amp might have e.g. IP sensitivity = 700mV for full power, and IP impedance of 100k, but these can vary from 140mV to 2V and from 10k to 1Meg respectively..
The preamp needs to have significantly lower output impedance than the amp's IP impedance. The preamp also needs to be able to supply the required signal voltage. The type and length of interconnect cable between the preamp and amp can also make a difference; if it's unusually long, it may need a lower preamp output impedance to drive it.
Preamp output voltage limit ashlar Car Audio 2 2nd December 2008 11:41 AM
High DC offset voltage at preamp output mmerig Solid State 18 23rd May 2008 07:44 AM
6922 Output Voltage (GC Preamp) JPannell Chip Amps 2 27th April 2005 02:23 PM
Rail Voltage VS Output Power ???? Zero Cool Solid State 10 18th October 2004 08:38 PM
Stupid question about voltage and output power Cro maniac Chip Amps 7 6th May 2004 11:33 AM
Page generated in 0.07487 seconds (69.79% PHP - 30.21% MySQL) with 10 queries
