online transformer info for newbies
Old 17th June 2007, 05:35 PM   #1
lt cdr data is offline lt cdr data  Wales
Default online transformer info for newbies
In response to posts looking for info about transformers, I thought i would bring all these together!!
http://www.valveheart.com/theory/transformer.html
http://www.geofex.com/Article_Folde...des/xformer.htm
http://members.tripod.com/richard98...former_math.htm
http://www.turneraudio.com.au/output-trans-theory.html
http://europa.spaceports.com/~fishbake/ot1/ot.htm
http://www.magnequest.com/mq_magnetics.htm
all sorts of info. in the MQ forum, too, do some searching
Feel free to add your own!!
May make sense to make this a sticky as there are all sorts of questions that crop up.
Old 17th June 2007, 06:17 PM   #2
http://members.tripod.com/richard984...ormer_math.htm
http://www.geofex.com/Article_Folder...es/xformer.htm
Old 20th June 2007, 01:38 AM   #3
jnb is offline jnb  Australia
Originally posted by Mike LaFevre
[once you remove the dc current from the primary of the OT (either SE or PP) then the copper current density is made much better because you don't have the heating effect (and I squared R losses) that accrue from the DC being added vectorially to the AC signal current. Or, in plainer english, the primary copper circuit (say it were wound with a 31 gauge wire) will appear effectively as though it were a larger guage wire once you remove the heating effects of the dc supply current.
How is this so?
Old 20th June 2007, 10:16 AM   #4
hmmm, not sure, I am sure tho that its talking about parallel feed, in both series feed cases with se and pp, you have the dc flowing : I think in push pull, even tho its supposed to cancel magnetically, you still get the primary heating effect of the current?
so in parallel feed, that only flows via the load choke, and the outupt tx is free just to use the ac only, thus, with only ac, effectively, you give the wire more headroom, as say, 1/2 of the capacity of the wire isn't taken up any more with dc
I think thats what he's saying, its poorly worded, as it gives the impression that the wire magically appears larger, whearas in reality it doesn't, its still got, say 31 guage capacity, but as you have taken away the dc, more is available for use by the ac signal
I really wish i understood transformers better.
Could anyone out there actually tell me the equation for the impedance calculation of the tx, ie not the ratio, or putting 8 ohms on the secondary will give 3000 ohms say.
but how you work out the Z from the inductance, load and winding resistances and all that....really struggling to put the pieces together
Old 20th June 2007, 10:52 AM   #5
I think the measured resistance of the winding will apply to the AC regardless of what DC is upon it. I have not heard of cable having a current carrying capacity like this.
The primary impedance (ie the reactance of the inductance) is
2 x pi x f x L.
For example, a 40H primary inductance at 20Hz.
2 x 3.142 x 20 x 40 equals approx 5,000 ohms.
DC resistance of the copper is supposed to be much lower than this so it has little effect.
If the primary has 20 times more turns than the secondary, the ratio is 20. 20 squared times an 8 ohm speaker equals 3200 ohms. That is what the speaker will look like to the primary. This needs to be less than the 5000ohms (which it is) or you need a different transformer.
BTW, I'm trying to view the valveheart websit you have recommended but it's been unavailable for some time.
Old 20th June 2007, 11:06 AM   #6
core materials:
http://www.audioasylum.com/forums/ma...sages/102.html
Old 20th June 2007, 11:10 AM   #7
Yvesm is offline Yvesm  France
Yvesm's Avatar
but how you work out the Z from the inductance, load and winding resistances and all that....really struggling to put the pieces together [/B]
You can find equations anywhere.
For the most part they are used inside that :
http://www.dissident-audio.com/OPT_da/Page.html
Just a tool that helps putting pieces together.
Yves.
Old 20th June 2007, 12:02 PM   #8
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
Some more tidbits: (scroll down a bit)
http://geek.scorpiorising.ca/articles.html
Old 20th June 2007, 03:03 PM   #9
Bonjour Yves.
I can't seem to install that program, any ideas?
Old 20th June 2007, 06:17 PM   #10
Yvesm's Avatar
Bonjour Yves.
Damned ! That is the worst that could occur
Where does it stop ? wich message ? if any !
Of course, you browsed the readmefirst file
Try to tell me more.
Yves.
online transformer info for newbiesHide this!Advertise here!
DIY output transformer info site smoking-amp Tubes / Valves 9 12th April 2010 11:35 PM
Kenwood Power AMP KM-X1 transformer info space2000 Solid State 0 21st June 2008 11:08 AM
Help finding Info For Hammond Transformer dismalonyx Parts 2 11th June 2008 02:06 PM
ST-70 Power Transformer Info rudy129 Tubes / Valves 4 10th March 2007 09:23 PM
info wanted about a output transformer goudfazant Tubes / Valves 9 22nd December 2004 05:16 PM
