diyAudio Sponsor
Closed Thread
Old 17th June 2007, 11:44 AM   #1
engels is offline engels  Israel
engels's Avatar
Lightbulb Yes, again: mains-powered KILLER amp without a power transformer.
And again I was thinking about all that electricity in the AC socket... so please tell me what may be wrong with the following idea:
Let's say, I've got a separate preamp with its own PT and line out.
The power amp has an input 1:1 isolation transformer.
Then I'm rectifying the mains (we've got 230 here) getting about 320V of B+. To save the filament transformer I'd use something like 50C6 tubes (50V@0.15A filament, 200V plates, 2.6K load, 6W output - is SE mode). Or maybe a more "conventional" 50L6 which is 3.8W into 4K in SE.
Let's say, I've got four 50C6 ($3.70 at Antique Electronics) or 50L6 ($7.40 at Antique Electronics) tubes in PP plus a phase inverter which is a bit hard to find but I guess it should be something like two 14A4 loktal triodes (12-14V@0.15A) or maybe two 14C7 ($1.95) pentodes wided as triodes (Couldn't find any 25V@15mA triode).
With all the filaments in series I get about 225-228V@0.15A
The OT is a bit of a question.... I'd love to make an OTL output (to compliment the PTL supply). The load for these 50V tubes is a bit odd.
So how may someone get killed with this type of amp? Or what bugs should someone expect?
Old 17th June 2007, 12:05 PM   #2
SY's Avatar
DEADLY DANGEROUS. Don't even THINK about doing this.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 17th June 2007, 12:43 PM   #3
diyAudio Moderator Emeritus
ray_moth's Avatar
I agree with SY, it's dangerous and not worth the risk. If you don't want to use a tranny for the heaters, stick to SS.
Closed Thread
Do I need to isolate the mains for switching power supply and traditional transformer Aaron323 Power Supplies 8 5th January 2006 09:46 AM
D-class amp NOT powered straight from mains kubeek Class D 10 28th December 2005 01:43 PM
D-class amp powered straight from mains? kubeek Class D 1 26th December 2005 04:33 PM
Page generated in 0.06556 seconds (69.33% PHP - 30.67% MySQL) with 10 queries
