diyAudio Sponsor
Old 17th June 2007, 11:05 AM   #1
Default Quicksilver 300b monoblock (KT88 conversion)
Any guidance re biasing early Quicksilver KT88 monoblocks converted to 300b? Only info available is that bias is to be 80ma, not 120ma as indicated on chassis near phono plug bias point. The conversion was done in Vancouver, Canada, but tech apparently has disappeared and did not supply a drawing. I see internet references to a bias meter supplied with QS amps when meter was not on-board, but any supplied with this amp is long gone. Chinese 300b tubes are only running @60%, but are matched, so wish to experiment with these before installing new 300b tubes. I rigged a mono phono plug with leads for autometer. Simply blows fuse, Need your insights and experience.
BTW - even as set-up (or not) these are quite remarkable for the price.
Barry
Old 18th June 2007, 02:06 AM   #2
Never seen the conversion. Can you draw the schematic?
Old 18th June 2007, 08:19 AM   #3
re Quicksilver 300b monoblock (KT88 conversion) - thanks for the response. Sounds like I may have no choice but to sketch the redesign. It may, however, be easier to comment on the changes. Does anyone have a schematic for the original KT88 monoblocks?
Old 18th June 2007, 10:22 AM   #4
The KT88 should be about the same as this.
Old 18th June 2007, 11:50 AM   #5
Thanks for the schema. Seems these are quite different. Preamp and drivers are marked on chassis 12FQ7 and 12FQ7or !2BH7. Output tubes are marked KT88 on chassis, but have been converted to 300B, with a corresponding increase in resistor and caps, as well as filtering with 5 large multicaps on top deck. Will sketch schema or note changes from yours and recall then post. Thanks, again.
Quicksilver 8417 conversion Original Burnedfingers Tubes / Valves 25 18th December 2011 10:33 AM
KT88 PP-5 Monoblock Amplifier zcables Tubes / Valves 4 26th January 2009 06:09 PM
Quicksilver conversion lpd Tubes / Valves 5 4th March 2008 10:38 AM
300b based monoblock plans space-cake Tubes / Valves 11 26th April 2006 09:30 AM
Quicksilver KT88 mono 60watt amp schematic Original Burnedfingers Tubes / Valves 105 9th February 2005 06:38 AM
Page generated in 0.07823 seconds (76.07% PHP - 23.93% MySQL) with 11 queries
