diyAudio Sponsor
Old 17th June 2007, 09:32 AM   #1
pwan is offline pwan  United Kingdom
Default Output transformer (SE) - DIY
Any guide/instruction/manual how to make the single ended output transformer? Thanks.
Old 17th June 2007, 10:01 AM   #2
design? or build?
buy one, its simpler.
or here
http://members.tripod.com/richard984...ormer_math.htm
http://www.turneraudio.com.au/output-trans-theory.html
http://www.valveheart.com/theory/transformer.html
Old 17th June 2007, 12:25 PM   #3
Alastair E's Avatar
Default Re: Output transformer (SE) - DIY
Originally posted by pwan
Any guide/instruction/manual how to make the single ended output tramsformer? Thanks.
O/P tx are probably the one most important component in the signal path. The design of them is something of a 'black-art' to most, but there is a guy here who has made a windows program to assist in their design. His name is Yvesm.
He is most helpful and assisted me when I made some for a 6C33C SE I made some time ago. I believe he has a newer version of his calculator for Tx's but I've not tried it yet.
If you have the materials available and the time, winding your own is most rewarding and satisfying, Things to keep in mind are the insulation and neatness of winding. A 'Lumpy' winding will take up valuable room on the bobbin and could make the coil too big to allow the iron to fit.
Most good transformer Co's use std sizes of iron and bobbins, as well as the insulation materials which are also std. sizes They are also good sources of the wire. I often get wire for various projects, as most winders will discard the 'dregs' left on a roll when they have large jobs needing an un-broken coil of several hundred meters length sometimes a friendly winder will give these free!....
Das Beste Oder Nichts
Old 17th June 2007, 05:03 PM   #4
Geek's Avatar
http://geek.scorpiorising.ca/windingtransformers.html
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.06797 seconds (82.01% PHP - 17.99% MySQL) with 10 queries
