diyAudio Sponsor
Old 16th June 2007, 09:24 AM   #1
cd149dc is offline cd149dc  Viet Nam
cd149dc's Avatar
Send a message via Yahoo to cd149dc
Default Help me.......What is the 6SN7 ???????
Hello,
Anyone could tell me what version of 6SN7 tube.
Thank you so much,
DIY forever
Old 16th June 2007, 09:17 PM   #2
gianis is offline gianis  Greece
Default 6SN7
6sn7 with ceramic elements???? Strange to me.....
Old 16th June 2007, 09:20 PM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi cd149dc,
I've never seen one like that either. It may be industrial, military or remarked Russian for all I know. If it is really a 6SN7, I'll bet it is not microphonic. Have you tried it in anything?
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 16th June 2007, 10:02 PM   #4
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Never seen it before. what does the stamp on the side say.. i cant see from the pictures.
anything on the bottom of the base?
Old 16th June 2007, 11:32 PM   #5
Ditto here.
Geometry looks like classic 6SN7 (have a normal one here), with anode surface somewhat larger. I guess that it is somehow a higher anode dissipation type, or designed to work in very hot areas plus perhaps conditions of vibration/shock.
Cd149dc, can you tell us where you found it or any more information? Most interested.
Old 17th June 2007, 11:25 AM   #6
ilimzn is offline ilimzn  Croatia
East German military 6SN7 (often has both US and russian markings) made by WF. I have a couple of those with the original labeling intact, it comes above the 6SN7 mark on yours. I'm not sure the elements are ceramic, but rather something like compressed mica. Still, they work very well...
Old 17th June 2007, 02:11 PM   #7
Brian Beck's Avatar
Very interesting tube. I've collected a lot of different 6SN7s, but I've never seen one like that. The ceramic support wafers have that "Red Bank" appeal.
As Johan suggests, the larger radiator fins coming off both sides of the plates ought to give a larger plate dissipation rating, all else being equal.
Ilimzn or cd149dc, do either of you have the East German part number, and the data sheet associated with it? I'm curious about how similar this tube is to a regular 6SN7.
Brian
Old 17th June 2007, 02:27 PM   #8
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
A picture of the Werk Fernmeldewesen type is
here
Maybe the previous owner no longer appreciated the Russian type marking.
Looks like Sponge Bob has killed another thread.
Old 17th June 2007, 03:49 PM   #9
Brian Beck's Avatar
Jacco's linked photo shows dual markings: 6H8C and 6SN7. The data sheet for the 6H8C suggests a near equivalent to the 6SN7. Max plate voltage and dissipation ratings are lower, surprisingly. Whether the 6H8C shares the fabled linearity of the 6SN7, I can't say.
6H8C data sheet
Brian
Old 17th June 2007, 04:42 PM   #10
anatech's Avatar
Hi Brian, Jacco,
That make sense.
Thank you for pointing out the datasheets.
-Chris
6SN7 pre-amp Andersen Tubes / Valves 57 17th July 2011 07:00 PM
SE 6SN7 amp.... JandG Tubes / Valves 24 6th March 2011 12:37 PM
6sn7's irishguy170 Swap Meet 0 15th January 2008 08:09 AM
Is it the 6SN7 or me? arnoldc Tubes / Valves 4 13th October 2006 12:31 AM
6SN7 CCS Cassiel Tubes / Valves 25 14th February 2006 11:09 PM
Page generated in 0.10967 seconds (78.59% PHP - 21.41% MySQL) with 10 queries
