| diyAudio Sponsor | ||
Hey Guys. Just got a noce pair of NOS Philips 10w 800 ohms fullrange speakers. I would like to build a 2A3 OTL amp. Possible? Any suggestions? Thanks in advance.
#2 |
4 2A3s in parallel? That would give a decent match... parafeed direct to the speaker.
Why not use the Philips amp circuit that was DESIGNED for this speaker? See Tung-sol 6CW5 data sheet for an example: http://datasheets.electron-tube.net/...127/6/6CW5.pdf |
#3 |
Thanks Tom - I did not know there was a specific amp made for these speakers. I did some searching on the web and in the forums with no luck. Why the 4 2a3's in parallel? Thanks again.
#4 |
I saw the circuit it looks good. I just like the triodes plus I have about 10 2A3's. Can you elaborate on the parafeed idea? Appreciate the help.
#5 |
The 2A3 likes a plate load of about 3K, so four of them should be happy with 800 Ohms...
You don't want B+ on the speaker wires, so use a choke for the DC load on the tubes and a coupling capacitor to the speaker. |
#6 |
Thanks Tom.
So say 70H to 100H choke between the B+ and the plates and a 2uf to 8uf cap from the plates to the speakers? Might also try a 6AS7 with both stages paralleled to see the results. |
#7 |
Magneto the Gravity Man
Parafeed is not OTL.
You might as well use them in PP with a transformer. Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#8 |
I here ya. Could just load it with a resistor.
| dimentions of speaker box in speaker spec sheet? | Dan2 | Car Audio | 2 | 6th February 2009 05:34 AM |
| Mounting speaker. Speaker gasket? | Cal Weldon | Multi-Way | 0 | 11th April 2007 10:36 PM |
| FS: Niles HDS-6L speaker selector w/ speaker protection. | Spasticteapot | Swap Meet | 0 | 27th May 2006 11:14 PM |
| New Ribbon Speaker Technology - Approach the perfect speaker? | cocolino | Planars & Exotics | 49 | 16th January 2005 10:12 PM |
| Pi Speaker Reviews/or Similar Speaker | G4ME | Multi-Way | 4 | 17th June 2003 12:26 AM |
| Page generated in 0.08486 seconds (76.32% PHP - 23.68% MySQL) with 10 queries |
