| diyAudio Sponsor | ||
I have a Symphonies Plus pre-amp..I like it. But I have the feeling that I could get something better with differrent tubes. Anyone have experiences they can share? A good reasonable preamo tube? Thanks Bruce |
#2 |
I recommend the Tung-Sol reissue 12AX7. It's a VERY good tube and it's very reasonably priced. I have a lot of customers who use them and the feedback has been really positive. It's quiet, low microphonics, and well made. It's a great value in a 12AX7, no doubt about it.
#3 |
Jim,
Thanks I have some phillips tubes as well as some old tungsrams. I have seem that ei makes a tube that seems ok and groove tubes mullard copy...You feel that the tung sols are better? The phillips that I have is a little grainy on the highs and the tungsram is warmer..but I hope to find something more open. thanks..and it seems that you could reccomend a place to buy them? Thanks B |
#4 |
First off, Ei is shut down, so finding an Ei ECC83/12AX7 is tough. And many were noisy or microphonic - the quality really slipped badly in the last of the production runs.
The GT "Mullard clone" can be a VERY nice tube as well. But the quality issues have darn near killed it. I stopped carrying them because the reject rate was over 80%! The GT is a warmer tube than the Tung-Sol, but the Tung-Sol has a very nice top end. One is not better than the other, they are just different. If you want more open sound the Tung-Sol is more likely to work for you than the GT. I hope it's okay to say I have the Tung-Sols in stock since you asked. |
| Alot of 12AX7's about | richwalters | Tubes / Valves | 84 | 20th August 2008 12:36 AM |
| 12ax7 | nigelwright7557 | Tubes / Valves | 6 | 1st June 2008 02:54 PM |
| 12AX7 how many is enough? | Sambeaux | Tubes / Valves | 19 | 23rd March 2007 07:31 PM |
| 12ax7 | Matthewong | Tubes / Valves | 0 | 12th June 2005 04:54 PM |
| Page generated in 0.08482 seconds (72.28% PHP - 27.72% MySQL) with 10 queries |
