| diyAudio Sponsor | ||
some circuit uses a very small value cap as cap input. But when simulating this on PSUD2, it seems the voltage on the 1st cap is very unstable.
Is there a reason for using such a small value? I was looking at diyparadiso and one of their designs uses .1uF. Thank you for the help |
#2 |
Jarthel,
The size of the input cap on a CLC filter is very important. With low values like 0.1uF the supply will act very much like an LC supply but with that 0.1uF at least providing a bit of high frequency (solid state diode switch noise for example) filtering. In my latest amp (6V6 Ultralinear drawing about 170mA for 2 channels) I used 5V4 recifier, off a 370-0-370 secondary, then a small cap, a 5H 200mA choke to 100uF/450V electrolytic and from there a separate feed via 10 Ohms to 60uF polypropylene for each channel. I found very small values gave a high output voltage (up around 360V) as I increased the cap the voltage dropped and provided a minimum (around 310V) with a value at around 1 to 1.5uF and then started to increase again with the voltage back at near the 360V mark with a 10uF cap. I used 2uF as the final value to give me 315 to 320V. PSUDII modelled that behaviour very well. I would hazard a guess that this is because with the smaller cap the rectifier (switcher), cap and inductor acts like a switching boost supply. With a larger cap the switching function does not occur or ooccurs to a lesser degree as the capacitors strored charge is then sufficient to maintain a current flow into the inductor when the rectifier switches off. Does that make any sense? Cheers, Ian Cheers, Ian |
#3 |
hi Ian, I was just wondering if the increased voltage was due to the 1st small cap being a PP type with a very low esr? Using a larger electro with an increased esr gave me a lower voltage when simulating. Thanks,
Phil. |
| choke input power supply filter | audionut | Pass Labs | 49 | 29th January 2012 05:38 PM |
| Has anyone using LC input in their power supply? | jarthel | Pass Labs | 27 | 7th April 2008 09:02 AM |
| Any interest in GC input buffer and power supply regulator pcb's? | Sheldon | Chip Amps | 149 | 3rd August 2004 01:24 AM |
| Choke input Power Supply | NickC | Solid State | 4 | 6th November 2002 07:41 PM |
| Page generated in 0.06160 seconds (81.57% PHP - 18.43% MySQL) with 10 queries |
