| diyAudio Sponsor | ||
I've got a small PP output transformer. I'm pretty sure I've identified the primary side. The leads are colored blue, red and brown. DC resistance from blue to brown is 416 ohms. Red is dead smack in the middle.
It seems there may be two (?) secondary windings. One seems to be have green and black leads. It's about an 11:1 turn ratio. The other has a yellow lead and a bare lead. It's about a 48:1 ratio. I think the yellow/bare might be good for a 9.2k ohm plate load into a 4 ohm speaker. I don't know what the black/green is supposed to do. The top of the frame is stamped 95-1625, 343832. It allegedly came off a Zenith console amp which used a pair of 6BQ5 for output tubes. Any ideas what to do with this thing? |
#2 |
Zenith used a number of transformers like this (and numbered their transformers 95-xxx). The extra winding was used for feedback. I have a couple, and may try the attached circuit... 6V6 amp
(untested - subject to change!) |
#3 |
my bet is on feedback as well.
| Mystery RF amp | spooney | Car Audio | 11 | 25th April 2008 06:14 PM |
| Power Transformer mystery lead.... | skittletata | Tubes / Valves | 2 | 3rd April 2008 03:40 AM |
| My mystery transformer. | azira | Solid State | 4 | 9th September 2007 06:42 PM |
| Transformer - mystery VA | seventenths | Power Supplies | 10 | 5th September 2007 05:47 PM |
| Mystery SE OPT | alexmoose | Tubes / Valves | 4 | 11th July 2006 01:29 AM |
| Page generated in 0.06785 seconds (69.35% PHP - 30.65% MySQL) with 10 queries |
