How to model psud2 using tube regulator?
Old 14th June 2007, 07:02 PM   #1
pchw is offline pchw  United States
Default How to model psud2 using tube regulator?
Hi all,
I want to build a preamp that uses 150V B+ and draws 20ma. Since I have some 0D3's around, that seems to fit the bill nicely. The 0D3 needs about 160V to start and needs to maintain a minimum of 5ma to avoid dropping out of regulation. So a couple questins:
1. when I model the PS using psud2, what kind of current load should I be using? 40ma?
2. To calculate the series resistor for the final voltage drop to 150V, what current should I be using? 40ma again??
Thanks!!!
- Fred -
Old 14th June 2007, 08:51 PM   #2
Tweeker is offline Tweeker  United States
You need to figure out how much current the 0D3 is shunting and model it as current tap, and use 20ma the load.
Id give the 0D3 more like ~180V at start up to be sure it ignites.
Be sure your foil hat has a good low impedance ground.
Old 14th June 2007, 09:09 PM   #3
Since this is a preamp, the current draw should be relative constant. Does 20ma sound right for the OD3 to shunt?
Let say the OD3 shunts 20ma, can you show me how to calculate the resistor before the 0D3?
Thanks!!
- Fred -
Old 14th June 2007, 09:51 PM   #4
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Thanks!!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th June 2007, 09:58 PM   #5
Zen Mod's Avatar
one more;
can't shrink it better
Old 14th June 2007, 10:01 PM   #6
Thanks a lot!!!
- Fred -
Old 14th June 2007, 10:03 PM   #7
Zen Mod's Avatar
Thanks a lot!!!
from some reason I can't upload second (last ) page ;
I'll try later.........seems momentary glitch on forum........
edit:
WTF!!!
I see it now........?!
anyway.........
Old 14th June 2007, 10:12 PM   #8
Zen Mod's Avatar
Default Re: How to model psud2 using tube regulator?
Hi all,
Thanks!!!
btw- as load use Constant Current Sink..........choose stepped one ;
for first (starting current) use just current through load (preamp) and as second step use summ of load and shunt current
How to model psud2 using tube regulator?Hide this!Advertise here!
EMC Model 200 Tube Tester Any Info Pls Dr ZEE Equipment & Tools 25 22nd August 2012 07:41 PM
PSUD2 Q on regulator JoshK Tubes / Valves 20 31st August 2007 09:27 PM
CircuitMaker Vacuum Tube model Steen Bentzen Tubes / Valves 20 11th October 2005 04:13 AM
Tube Spice Model Problem valveitude Tubes / Valves 5 5th July 2005 01:56 AM
Building a tube Model???? SGregory Tubes / Valves 1 20th October 2004 01:51 PM
