diyAudio Sponsor
Old 15th June 2007, 05:34 PM   #21
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Just keep the 10k for the moment and see what it sounds like.
Ps...did you try to post another picture? I don't see the rp in green...
Old 15th June 2007, 08:13 PM   #22
pwan is offline pwan  United Kingdom
Yes, here it is.
Old 15th June 2007, 08:33 PM   #23
I'm not sure if there is a standard notation. But the plate resistor I think should be called Ra (Resistance Anode)
The Rp is the internal resistance of the tube? (Someone please correct me if I'm wrong)
Anyway keep the Ra 10k for the time being.
And yes, if you can add additional filtering in the form of an RC network for the driver stage and feed that with a higher B+
Old 15th June 2007, 09:09 PM   #24
Dave Cigna's Avatar
Generally speaking, fixed values (like load resistors) are represented by upper case letters while dynamic values (like plate resistance) use lower case.
For the subscript, both 'a' (anode) and 'p' (plate) are used, though it seems that 'p' is used mostly by people in the US. Worldwide, 'a' is more common.
So a load resistor can be either Ra or Rp. The plate (err... I mean anode) resistance of a tube can be either ra or rp.
If you're an old codger that still programs in FORTRAN then everything is upper case.
-- Dave
January 20, 2009: Bush's last day
Old 15th June 2007, 09:13 PM   #25
Thanks for the explanation.
Old 16th June 2007, 03:34 AM   #26
Originally posted by Dave Cigna
....If you're an old codger that still programs in FORTRAN then everything is upper case.
[/B]
No I programme COBOL
Thanks for your advice. However, I quickly looks on a local electronic book here and a few paragraph mention that the ratio of Rp(or Ra) of the first stage and the Rg of the 2nd stage should be around 3-5 for Cap interstage coupling. Have you ever heard that golden rule?
And go thru my schematic collection (~ 14 ones) and all of them comply with that guide line. In the circuit I just posted, the ratio 150K/10K = 15 which is much higher. Will it be any problem esp. on stabability & sonic degrade?
Old 16th June 2007, 05:38 AM   #27
Yvesm is offline Yvesm  France
Yvesm's Avatar
Larger is better
Yves.
Old 16th June 2007, 10:16 AM   #28
Originally posted by Yvesm
A quick check with Tube CAD.
Is the Tube CAD a computerized aid design software? Is it a freeware/shareware? Any hint where I can get it (at least for trial)? Thanks.
Old 16th June 2007, 11:20 AM   #29
SY's Avatar
It's not freeware, but it's pretty cheap. You can get it through www.tubecad.com or www.tubesandmore.com .
The "free" way to do this is by the use of load-lines and graphical construction.
Think of that as an absolute minimum. Tubes generally show the least distortion with the highest possible loads.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 8th April 2008, 09:12 PM   #30
vizion is offline vizion  United States
Default EL84 OTL
how many EL84s would it take to get 4.5 watts @ 5 ohms in an OTL configuration ? 30 ?
Stage output, driver oscillating Rafael L Solid State 20 19th May 2009 07:31 AM
SE EL84 output stage? Lingwendil Tubes / Valves 2 29th June 2008 05:55 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
driver stage for CFP output. RichardJones Solid State 0 21st April 2003 07:46 PM
Page generated in 0.10245 seconds (78.35% PHP - 21.65% MySQL) with 11 queries
