Please review my 6AQ5 Amp
Old 13th June 2007, 01:50 PM   #1
PRNDL is offline PRNDL  United States
Default Please review my 6AQ5 Amp
I've been modifying an old Dynavox 6AQ5 amp for guitar and thought it might be a good idea to have someone else review my schematics.
I'm waiting for parts to the tone stack. The amp sounds pretty good without it, and seems to have enough volume. It distorts fairly early (around 3:00), but adding the tone stack will change that.
I used a simple concertina phase inverter without feedback in order to increase gain. It was an experiment that worked great.
There is an empty spot for a second preamp tube, but I decided not to use it in favor of the simpler design.
Thanks!!
Schematics
http://www.naturdoctor.com/Downloads/Dynavox_1.pdf
Old 13th June 2007, 02:54 PM   #2
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
As drawn, you have unequal drive to the output tubes - it's close to being single-ended! The plate and cathode load resistors must be equal for equal drive levels (47K or so?). This will require two additional changes: the grid of the concertina will be biased positive, so it will need a coupling cap, and gain will be greatly reduced (to a gain of ONE), so you'll need the extra preamp stage. If you have a seven pin socket, use a 6AV6 or 6AQ6 (half of a 12AX7), or even a 6AU6. If it's nine pin, you have more choices.
Also - R24 CAN'T be 22K - typo?
Old 13th June 2007, 03:34 PM   #3
Thanks Tom ... I'm glad I posted!
Yes, R24 is most likely not 22K. I haven't measured the resistors in the power supply.
It looks like I'll have to order some more parts for the extra tube/gain stage.
Is there a benefit for switching from cathodyny to to a long-tailed phase invertor?
I know that you get gain with the latter, but is there a big difference in tone/distortion?
Old 13th June 2007, 04:07 PM   #4
kevinkr's Avatar
LTP is generally the standard driver topology in pp guitar amplifiers, I'd give it a try.. I think with the LTP you might have almost "enough" gain without an additional stage, provided you don't plan on adding NFB later on.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 15th June 2007, 11:08 PM   #5
Default Updated amp needs checking
I've updated the amp by adding another 12AX7 and built it, but it doesn't sound right. It sounds OK with very low volume.
Either there's a mistake somewhere, or some of the caps I had on hand were the wrong values.
I'm concerned about the coupling caps (C1=.02, C5=.01) and the phase invertor cap (C6=.1, which should be .01). My guess is that C6 is off.
I've had it for the evening, and am going to play guitar.
Any suggestions?
Thanks again!
Old 15th June 2007, 11:20 PM   #6
Brian Beck is offline Brian Beck  United States
Brian Beck's Avatar
You're feeding the grid of V2 through a 1M resistor. Try connecting the right end of C5 to the grid.
Brian
Old 15th June 2007, 11:21 PM   #7
kevinkr's Avatar
C5 should go to pin 2 of the driver ltp.. Hopefully not wired as drawn..
Will think about this over the wk end.
Old 16th June 2007, 12:47 AM   #8
Would you believe that it sounded better with C5 wired incorrectly?
Oh well.
Here are some voltages
V1.a 6=158, 8=1
V1.b 1=129, 3=1
V2: 1=173, 2=18, 3=51; 6=174, 7=18, 8=51
V3: 5=261, 6=237, 2=15
V4: 5=260, 6=238, 2=15
PS: A=287, B=265, C=237
The amp squeals with the volume off zero, so I may need to add NFB to reduce overall gain. I'm also driving the 6AQ5's slightly higher than the max (250).
Old 16th June 2007, 01:31 PM   #9
Default Copy a 6G3 Deluxe
I've read several times that the 6AQ5 is a similar to a 6V6, so I decided to look in the Book of Fender and found that the 6G3 Deluxe has 6V6 with LTP PI.
Attached is a revised circuit.
Old 16th June 2007, 01:54 PM   #10
Tom Bavis's Avatar
You have the first three stages and the output screens all connected to the same power supply tap. You might try adding a 10K resistor and another electrolytic to supply the two input stages. This "de-coupling" may solve the squealing...
Please review my 6AQ5 AmpHide this!Advertise here!
Socket for 6AQ5 Stuey Tubes / Valves 28 22nd January 2009 08:39 PM
Help with 6AQ5 schematics kacernator Tubes / Valves 5 17th January 2008 11:46 AM
Driving 6AQ5's jerluwoo Tubes / Valves 10 22nd June 2007 05:08 PM
6aq5.......6v6....... diesel_tech Tubes / Valves 9 23rd February 2007 12:43 AM
Which 6AQ5 dstockwell Tubes / Valves 4 12th December 2005 11:05 AM
Copyright ©1999-2017 diyAudio
