diyAudio Sponsor
Old 13th June 2007, 12:10 PM   #1
alexg is offline alexg  Philippines
alexg's Avatar
Default 832A PP Amp LTP
I am building an 832A PP amp based on the attached schematic from ultranalog.com.
Unfortunately, I cannot source the transistor for the CCS, if I have to replace it with resistors, would I need a cathode resistor and then a tail resistor? How do I compute the values?
If I wanted to replace the driver/phase inverter tubes with a tube with octal base, any recommendation?
Would 6n1p work instead of the 5670?
Thanks.
Old 13th June 2007, 12:45 PM   #2
analog_sa's Avatar
Replacing with a resistor is not a good idea. You might need a negative supply voltage or at least raise the main supply.
Why don't you just use other npn transistors? I can't see supermatching being important here. Or just use another type of CCS - many options.
Old 13th June 2007, 02:43 PM   #3
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Alex, those transistors are available at our local Farnell (Order code 9605088 ) and RS Components (Order code 522-9868 )
If you should replace those with resistors, I'd suggest a negative supply.
Why not use the diyAudio CCS?
Old 13th June 2007, 03:12 PM   #4
Svein_B is offline Svein_B  Norway
I think a negative supply is higly recommended for the CCS. As shown, there is very little voltage for the CCS to work with.
A small 6-12V transformer salvaged from an old fasioned power supply should work fine. Then you will be free to use the DIYAudio CCS, or any other CCS of your choice.
SveinB.
Old 13th June 2007, 07:12 PM   #5
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
alexg,
2sc945, & 2sc1815 are common, there are lots of to92 npn trannies that are available, they are abundant as they are cheap in RAON.
832A Push Pull 5W morfeas Tubes / Valves 67 4th July 2011 05:58 PM
Just finished testing my first 832A amp Pyre Tubes / Valves 44 16th March 2010 03:09 AM
Plate Caps for 832A mb3k Tubes / Valves 18 30th May 2007 04:58 AM
832A transmitter tube Mr. Triatic Tubes / Valves 0 3rd March 2002 08:47 PM
Page generated in 0.09489 seconds (71.88% PHP - 28.12% MySQL) with 11 queries
