| diyAudio Sponsor | ||
Hi, I'm new to this forum and was wondering if anyone knows about converting bogen p.a amps for guitar use? My friend knows a little bit about electronics and helped me draw this schematic up. We're trying to modify the bogen chb 35a schematic to yield similar results to a model 1987 plexi. We're keeping the bogen transformer and trying to create a hybrid with a plexi schematic. I was wondering if someone could look at the schematic and tell me if it is set up right? I know if we use the bogen transformer we have to use the bogen schematic for the power supply. Any or all input would be more than welcome and greatly appreciated. Thanks
#2 |
You're on the right path.
The first gain stage (Mic) needs some work ... Put a 1M to ground on the jack, and a 47K grid resistor to V1. Then move the master volume after the tone stack. |
#3 |
The DPST switch shown as standby is, in fact, a complete on/off switch. A standby switch will not remove power from the tube heaters.
To obtain the standby function, a SPST switch rated for 240 VAC and several Amperes service needs to be inserted into the red/yellow lead from the power trafo. Replace the voltage doubler diodes with UF5408s. Replace the bias supply diode with a UF4007. 40 muF. caps. in a doubler stack look wimpy to me. More capacitance is definitely needed. The $64 question is how much more capacitance can the power trafo stand, without overheating. I'm guessing that an extra 33 muF. in parallel with the 40 muF. parts will be OK. No matter what, you MUST replace all electrolytic caps. in the amp. 'Lytics literally dry out over time. Be sure to read the "sticky" thread about safety on this forum. A mistake with this stuff gets you DEAD.
Eli D. |
#4 |
Thanks PRNDL, I will change the schematic up. I really appreciate the help.
#5 |
Thanks Eli, good call on the caps and standby switch. I will check out that "sticky" thread as well.
#6 | |
Eli D. |
| Another Bogen CHB 100 Conversion | dwdw | Tubes / Valves | 0 | 26th March 2009 12:46 PM |
| Bogen CHB-35 to conversion to B-12/B-15 | hearforever | Tubes / Valves | 0 | 12th January 2008 07:48 AM |
| Bogen 8417 tube conversion..? | Nichols | Tubes / Valves | 77 | 8th December 2007 06:57 PM |
| Bogen CHB-10A Conversion, need help and advice | Turbo7MN | Tubes / Valves | 14 | 22nd August 2006 02:29 PM |
| Another Bogen Conversion | Turbo7MN | Tubes / Valves | 12 | 20th May 2006 11:55 PM |
| Page generated in 0.07892 seconds (78.72% PHP - 21.28% MySQL) with 11 queries |
