| diyAudio Sponsor | ||
At some point I've oredered a matched pair of 7C5's at Antique Electronics (for those of you who don't know, 7C5 is 6V6 with loktal base). Today, as I'm finishing a PP 7C5 amp I've pulled the tubes out of the boxes - the boxes look the same - and what a surprise, one tube is GE and the other is Sylvania. They ARE matched but still I wonder what the heck.
I also have a bunch of unmatched RCA 7C5's and I plan to perform a listening test. Is it accepted to have matched pairs of different brands??? |
#2 |
Totally, Engels.
I know the appearance might disturb slightly, but that is all. Tubes of the same number should have the same characteristics irrespective of brand, and particularly with NOS from GE and Sylvania I would not have a worry. Regards. |
#3 |
It is possible that the Sylvania was made by GE or vise versa. This is not uncommon. If the tubes are of similar internal construction, don't worry about it. I have matched up several pairs of tubes of different brands.
I bought a bunch of used Russian tubes, and set out to make some matched pairs. One of the best pairs is an Electro Harmonix KT88 paired with an Electro Harmonix 6550. This is why I believe that New Sensor puts two different numbers on the same tubes.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#4 |
Very interesting!
The same Russian story all over again. |
#5 | |
#6 | |
In the case of Locktal types, things may go even deeper. Forget the branding. How many plants actually produced tubes with Locktal bases? I would not be surprised if all Locktal tubes came from as few as 1 location.
Eli D. |
#7 |
In my case GE is a fraction taller; the plate material seem to be a little different (Sylvania being the "blackplate" and GE something more grayish) , different internal construction and getters. Even the bases (the metal rim) look different. Definitely not from the same plant.
#8 |
Engels,
Yes, this is also the case with other brands, even some NOS. As a user of 6L6GCs in products I sell, I am constantly a little nervous. The classic oval shaped anodes, with larger and smaller radiating ribs either side, very large G1 radiators on the GE (goody!) but NO G1 radiating plates on the Sylvania! Then the box type anodes (black, dark grey, light grey, somme ribbed, some not) on a variery of very good (hopefully) 6L6s, some Russian 6L6GCs definitely no more than ...GBs, etc. Yet they measure the same, and one is encouraged by the statements of "tube veterans" like Tubelab. Who knows - anything is possible these days..... |
#9 |
Eli,
Yep, I do suspect you are on the mark. |
| FS: Matched pair NOS RCA 5670 | cartman | Swap Meet | 2 | 10th December 2007 09:12 AM |
| FS: Matched pair NOS CEI 2C51 | cartman | Swap Meet | 0 | 10th December 2007 09:07 AM |
| how do you know you need matched pair? | jarthel | Tubes / Valves | 4 | 11th May 2007 04:57 PM |
| WTB: 5692 (matched pair) | cartman | Swap Meet | 0 | 11th June 2006 07:25 AM |
| i have a matched pair of 3cx1000a7.. | Mr. Triatic | Tubes / Valves | 8 | 4th October 2004 09:29 PM |
| Page generated in 0.12398 seconds (80.57% PHP - 19.43% MySQL) with 10 queries |
