diyAudio Sponsor
Old 25th January 2003, 11:48 PM   #1
Default jack probs
hey everyone i just put my head in shop to be fixed because of alot of cackling and cuttin out on the low input channel well ig ot it back anbd it was worse so i plan on tacklin it myself
i kno its a loose jack connection or sumthin to have to do w/ the jack. when i push up on the jack its crystal clear soon as i let go the problems start again, what should i do?
love the bud, cherish the bud
Old 26th January 2003, 11:48 AM   #2
It sounds like you are describing a 1/4'' female jack, if so replace it because its worn out.
Joe
Old 26th January 2003, 02:43 PM   #3
how much do they usually cost? do i need to souder anything? i'v never replaced a jack b4
Old 26th January 2003, 03:17 PM   #4
Joel is offline Joel  United States
Joel's Avatar
They cost $5. You need a female, "shorting-type". Yes, you will need to solder a resistor and two connections. Schematics of most amps can be found on the web, and will show the jack wiring.
Old 26th January 2003, 11:15 PM   #5
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Make sure its not your lead... They get chewed up pretty easily...
Old 27th January 2003, 12:27 AM   #6
my lead? i'm confused... i have two inputs high-low the low is the bad one
Old 27th January 2003, 04:48 AM   #7
SHiFTY's Avatar
lead = big bit of wire with plugs on, used to connect amp to guitar...
Sounds like its definitely your socket /jack though. Just swap it out for a new one, or find a friend who can do it for ya!
BTW why didnt the shop fix that? I hope you didn't give them any moneys.
Old 28th January 2003, 01:42 AM   #8
Default shop
the shop insisted it was dirty pots, i bought it from them, brought it back, they kept it for 2 1/2 weeks and gave it back-and it sounded worse, i didn't pay them anything because of a warranty type deal....how much do soder guns run at?
2 Mono Jack to Female Stereo Jack JellyMan Everything Else 2 27th May 2008 03:39 PM
making dual mono jack from single mono jack dubmunkey Analog Line Level 2 12th October 2006 02:16 PM
oscillation probs leander Solid State 1 31st October 2005 12:32 PM
Page generated in 0.08201 seconds (70.34% PHP - 29.66% MySQL) with 10 queries
