diyAudio Sponsor
Old 8th June 2007, 08:54 PM   #1
Sir Trefor's Avatar
Exclamation Heathkit Schematic model AA-50 needed
I took this amp apart and carefully made a schematic as I went, and now i've lost the schematic. I cannot find this anywhere on the web. I tried to connect it from memory to no avail.
Specifically I need the schematic for the PSU; it has a 5AR4 rectifier along with 5 caps(60, 25, 40, 40, 20 [500V]). There is a 10w 1.5 kOhm wirewound resistor connected to pin 8 of the rectifier- I had connected this to the (+)terminal of the 60uF cap along with the centre-tap lines from the OPTs- assuming this was my positve volatge- am I incorrect?
"This is just my 'one cent'; I haven't got two to give."
Old 8th June 2007, 11:08 PM   #2
Try pinging Tom Bavis. IIRC, he has the AA-50 schematic.
Eli D.
Old 9th June 2007, 12:30 AM   #3
Tom Bavis's Avatar
You rang?
I'm afraid I don't have that one... but it's one of the few Heathkits that was covered in Sams Photofacts... folder 544-7 to be exact. Check with your local library...
Old 9th June 2007, 12:35 AM   #4
Sir Trefor's Avatar
Thanks for the help, guys
Old 9th June 2007, 01:05 AM   #5
Sir Trefor's Avatar
Their website appears to be down... I'm assuming that the 'check my local library' comment was facetious? Or might the Fresno, California Public Library have information I can use?
Old 9th June 2007, 01:51 AM   #6
No he is not being facetious!!! Library used to have (and still may)
have tons of Sams. I have gotten 2 from my library in the bay area in the last 1 1/2 years. Victoria
Schematics needed for Heathkit S33 DoomPixie Tubes / Valves 6 15th February 2006 09:24 AM
Heathkit S-33 Information needed. DoomPixie Tubes / Valves 19 20th July 2005 11:31 PM
Heathkit AA-181 schematic needed bobhedberg Tubes / Valves 0 15th November 2004 06:55 AM
HOW to use a Heathkit Model 10-18 oscilloscope Dusk Solid State 7 14th October 2004 10:00 AM
MXR Equalizer Model 170 schematic needed rh1530 Instruments and Amps 0 24th January 2004 01:54 AM
Page generated in 0.07969 seconds (70.70% PHP - 29.30% MySQL) with 10 queries
