diyAudio Sponsor
Old 25th January 2003, 12:18 PM   #1
316a is offline 316a  England
316a's Avatar
Question 3 Electrode gas regulators
Hello Folks ,
I have pile of these very handsome STC/ITT loctal G180/2M gas regs which glow a very pretty pink colour . As I'm sitting on an enourmous pile of loctal sockets (plus I was a little bored!) , thought that pressing a few of these into action would be a good idea for my latest prototype . I've hunted down the datasheet which details a third electrode 'AA' , but what is this for ? On the datasheet (page 2) it shows an additional series resistor linking to this 'AA' pin but no value for this resistor is specified
http://frank.nostalgiaair.org/short/054/4/493.pdf
...what do I do with this pin ? Leave it floating or 'wing it' with something like 470k etc . Sorry for the naivity , any sensible suggestions welcome
316a
Old 25th January 2003, 12:37 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Sensible? We'll see..
Hi 316a,
I would hazard a guess that it's for reliable firing.
The 470k option sounds a good idea!
Old 25th January 2003, 01:16 PM   #3
dhaen's Avatar
Default Fired
316a,
Just noticed that on page 1 it gives the Uaa voltage.
By now you've probably already determined what's going on anyway.
Old 25th January 2003, 01:22 PM   #4
316a's Avatar
Default Primer
...you mean like a primer pin ? I fired them up without AA connected and the things still seem to work alright . I've been adding more resistors in parallel across them and it's sitting quite happily , only the ripple increases , probably as I've only bypassed each one with a 0.015uF oiler . I'm using these stacked so will connect AA to to A or each respective regulator . The wife should like these , just her colour !
316a
Old 27th January 2003, 12:57 PM   #5
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Are we talking punk pink or baby pink? A regulated HT supply with mercury vapour rectifiers (cue the safety posts) and these references could be a work of art.
Old 27th January 2003, 01:20 PM   #6
316a's Avatar
Default .hmmmm
...certainly not a natural looking pink ! I'm tempted to add another pair of sockets and use a pair of these loctal QS108/45 EE things instead and a single G180/2M , making a stack of three per side . This would mean an 8 valve stereo concertina input stage ! I'm tempted to use a gas reg for the negative bias supply for the output stage , got so many of the things ! I have a set of RG1/250 mercury vapour , but this project will use the cheap as chips PY500a instead .
316a
Magnat Plasma MP-02 Electrode and other maxitu1 Planars & Exotics 3 16th April 2007 07:36 AM
Using Gas Regulators alexmoose Tubes / Valves 8 21st December 2006 06:48 AM
+/- with pos and neg regulators vs 2 pos regulators mr.duck Power Supplies 8 12th October 2006 04:27 AM
Regulators carlmart Solid State 28 11th March 2003 01:55 AM
Page generated in 0.07002 seconds (83.14% PHP - 16.86% MySQL) with 10 queries
