GU 50 output modification
Old 14th December 2009, 09:50 PM   #21
adam2a3 is offline adam2a3  Greece
Hello, I am using a pair of GU50's in place of KT66's in my homemade QUAD II amp. The output transformer is an original Quad. The only extras (apart oil caps in place of the TCC electrolytic) is a string of 2 voltage regulator tubes that set the screen voltage to approx 300V. In series and very close to anode pins I put 33R small resistors that helped to eliminate a small oscillation that appeared before clipping. The output power is approx 19W sine continuous @ 15 Ohms. This is driving an LS3/5a as a center channel in my home cinema.
Old 20th December 2009, 10:32 AM   #22
ja2dhc is offline ja2dhc  Japan
Send a message via AIM to ja2dhc Send a message via MSN to ja2dhc Send a message via Yahoo to ja2dhc
Originally Posted by beamnet View Post
Just connect G2 to the anode with 100 ohm and g3 to the cathode?
The attached file is the schematic of a Chinese Amplifier which I bought last year.
G2 is connected to Plate via 200ohm. Plate voltage is 520V.
G3 is not described in this schematic but it is connected to the Cathode
in the datasheet.
Old 15th January 2010, 03:02 PM   #23
mavallarino is offline mavallarino  United States
mavallarino's Avatar
Default Strange Schema
Hello,
I'm interested in constructing a GU50 PP amp and I discovered this thread to gather some ideas. Has anyone constructed one and what are the best drivers for this?
I would be prudent in believing that schema.
I would also verify if you actually have a choke for the driver stage. The chinese like to indicate choke but give you a nice military res instead.
What is the voltage on the grid and where's the power supply for it?
GU 50 output modificationHide this!Advertise here!
dCS modification. timcatn Digital Source 77 3rd August 2009 01:06 PM
X-over modification hermanho Multi-Way 1 20th February 2006 06:52 AM
Amp Modification shajan Solid State 3 5th January 2004 06:21 PM
Help with CD modification primalsea Digital Source 1 20th April 2003 08:06 PM
