| diyAudio Sponsor | ||
I'm preparing an amp with the el cheapo phase-splitter and after searching the web found a recommendation from Eli for getting enough voltage out of a 6v heater winding for the B- supply. He recommended a half-wave parallel voltage multiplier with about 7 diodes. (Newby question following) What would be an appropriate value for the multiplier (not filter) caps in that circuit? Thanks! Simon |
#2 |
Simon,
The multiplier caps. are filter caps. It's the nature of the beast. A stereo amp using the 'T7 splitter/driver needs 12-14 mA. of B-. Schottky diodes eliminate SS rectifier switching noise. Therefore, using Schottkys is obvious. If the multiplier caps. are large enough, the ripple fundamental (50 Hz. in the EU) will be well squashed, but the overtone "hash" will be significant. My seat of the pants guess is to use 100 muF. 'lytics in the multiplier, follow with a 10 mH. RF choke to kill "hash", and finish up with 220 muF. 'lytic.
Eli D. |
#3 |
Got it, thanks alot!
Simon |
| page Eli Duttman's Simple p-p with 5965 MQ EXO-173 and 6AQ5 | Norris Wilson | Tubes / Valves | 25 | 15th August 2008 07:58 PM |
| Quick FET question | spooney | Car Audio | 2 | 5th December 2007 05:05 AM |
| Quick quick question ! | guitvinny | Pass Labs | 6 | 7th February 2007 04:20 PM |
| Quick question.. | bafke | Multi-Way | 5 | 11th November 2003 02:47 PM |
| Page generated in 0.07700 seconds (74.64% PHP - 25.36% MySQL) with 10 queries |
