diyAudio Sponsor
Old 5th June 2007, 11:50 AM   #1
nazgul is offline nazgul  Croatia
Default Tube XP8109-02?!
Recently, I had an opportunity to obtain fair amount of tubes of all sorts.
Among the others, there was tube (at a first glance simmilar to 300B) that bears only marking XP8109-02 on the outer glass surface.
I tried extensive internet search about this tube...needless to say, without success )).
Does anyone knows anything about this tube?!?
Thnx
"...Give me just one PING Vasily...One PING only, please!..."
Old 5th June 2007, 04:23 PM   #2
ilimzn is offline ilimzn  Croatia
A picture might help, or you can contact me through the audiofil.net forum in croatian.
Old 6th June 2007, 06:45 AM   #3
Sorry ilimzn, you're right, my mistake... Here is pic... and I'll try to contact you at the mentioned location...
thnx
Old 8th June 2007, 01:06 PM   #4
Alastair E's Avatar
Looks like some kind of tetrode or hexode used in the I.F amps of radios....
Just a wild guess....
How many grids does it have....?
Das Beste Oder Nichts
Old 11th June 2007, 12:21 PM   #5
@Alastair E.
First of all, thnx for showing interest to help! I would say that it has two grids, but I'm not 100% certain...
Do You maybe have some usefull links where I can try and search some data regarding this tube. All the usual ones I tried... maybe something unusual )... Is there anything that You might say about this tube from the designation number... even remotely?!? )
Old 11th June 2007, 02:31 PM   #6
It would help greatly if you could post a really close-up pic of the electrode system. I've been trying to look at the enlarged version of the pics you put up but the resolution is simply too low.
Still, the external shield cylinder and some details on how the electrodes are arranged lead me to believe it might be a gas filled tube... so you should be prepared for a dissapointment, as these are not really usable in audio. That being said, i might be dead wrong, it's too early to tell. Where are you in Zagreb? Having a look at the tube close up might help...
Old 13th June 2007, 08:23 AM   #7
Hi ilimzn,
First of all, dissapointment is out of the question due to the fact that I have only 9 of those tubes in, and among, of the stash that includes several hundreds of tubes of all kinds (primarilly russian made ones).
My interest in this tube type is just an interest shown when one has something that is unknown to him... and then one gets angry and frustrated
Zivim u Sv. Nedelji. Pokusao sam kontakt preko audiofil.net-a, ali za logiranje je potrebna web adresa koja nije web mail. Kako nisam bas voljan samarati svoju web adresu naokolo bezrazlozno nisam se logirao .
Ako imate vremena i mogucnosti, mozemo se dogovoriti pa dofuram cijev da pogledate...
thnx
Old 13th June 2007, 08:23 AM   #8
@ilimzn
...naravno, grijeska ... u prethodnom postu, u hrvatskom tekstu, rijec web adresa potrebno je zamijeniti sa mail adresa ...
Old 13th June 2007, 02:14 PM   #9
Originally posted by nazgul
[B]Hi ilimzn,
Well, well we may arrange a swap-meet
I appologise to the readers of the thred for the Croatian text, i promise to keep it brief as it will solve the problem faster...
Zivim u Sv. Nedelji... Ako imate vremena i mogucnosti, mozemo se dogovoriti pa dofuram cijev da pogledate...
thnx
0915964100 Zeljko (najbolje SMS-om) pa se lako dogovorimo, ja sam doma u Zapresicu, a na poslu u centru ZG.
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 06:47 AM
Page generated in 0.10337 seconds (76.88% PHP - 23.12% MySQL) with 11 queries
