diyAudio Sponsor
Old 5th June 2007, 01:55 AM   #1
Jaime is offline Jaime  Uruguay
Jaime's Avatar
Default Microphonic phono preamplifier
How many microphonic can be an phono preamplifier and have good sound?
It is tolerable some?
Where are an article about the redution of it?
Best regards
Jaime
I write in English worse than Tarzan
Old 5th June 2007, 02:01 AM   #2
FastEddy's Avatar
Jaime: See http://www.bottlehead.com/et/music/digitaljimmyhat.htm ... This is an update service for microphone pre-amps ... but a good place to start.
You might also ask these questions at their forum: http://www.audioasylum.com/forums/bottlehead/bbs.html ...
Old 5th June 2007, 12:28 PM   #3
Miniwatt's Avatar
Jaime's question was about microphonic phono stages, not mic preamps
Can't say anything about it, my preamp is not microphonic at all, even when I tap the tubes..
Old 5th June 2007, 02:52 PM   #4
FastEddy's Avatar
" And this is then the overkant, remembers you that therefore well because that is important when you must cross ..."
Hi-end Phono vacuum tube preamplifier MM audiodesign Vendor's Bazaar 0 5th March 2009 06:31 AM
Transparent, Non-Microphonic Input Cap for Phono Preamp? thermionic Solid State 7 31st July 2008 09:17 PM
Phono preamplifier Pasul Analogue Source 4 4th October 2006 11:03 AM
Help with phono preamplifier selection Panelhead Solid State 7 24th November 2003 11:24 PM
Page generated in 0.06924 seconds (68.52% PHP - 31.48% MySQL) with 10 queries
