diyAudio Sponsor
Old 4th June 2007, 06:15 AM   #1
jnb is offline jnb  Australia
Default OPTs and power for bi-amping
If the spectrum is split 50/50 (like 300-400Hz) using two identical amps, is it easier to drive the highs because the amplitudes are lower or not.
Does a 45 sound powerful enough at 1.5 W for the highs if I split at 1500Hz? My speakers are not that sensitive <90dB.
I have some various sinle ended OPTs from unsalvageable old radios and TVs. The iron is typically 5cm^2 (2' x 2') can it handle the power of the 45 at those frequencies if I can find one with the right inductance and ratio?
Old 4th June 2007, 11:38 AM   #2
HI JNB
I do not know if your first sentence is a question or a statement, but here is an article by Broskie that may shed some light on it.
http://www.tubecad.com/articles_2001...s_and_Filters/
Just a personal opinion on the combi tube + OPT you are planning. It may work well, but I expect the 45 tube to be 'to good' for the OPT's you are planning to use - at least the 45's are too expensive. Personally I would sell the 45s, buy some better iron from the money and run a a SE amplifier with a cheaper valve as a EL84 in triode, which will give the same power (I think), but probably much better due to the better OPT (much people consider OPT to be the weakest link in an amp...) But this is just my humble opinion!
Erik
Old 5th June 2007, 07:46 AM   #3
The reason for my question is because I read that there is 70% of the music power present below 1500Hz.
If this is true, I figure the 1.5W amp will compromise the system if I try to run it louder than what a 5W full spectrum amp would go. In other words, it seems that any more than 3.5W for the bass amp and the tweeter amp will distort first.
Or am I wrong?
Ask Jan First OPTs Psychobiker Tubes / Valves 6 2nd March 2008 09:33 AM
WTB: OPTs for 2A3 or 45 SE; 240 v power tranny for 2A3 or 45 rick57 Swap Meet 0 8th November 2006 01:07 AM
RAIL power supply / BI Amping question Bifi01 Solid State 4 24th August 2004 06:02 AM
SE design using 10k OPTs roundel325 Tubes / Valves 7 16th June 2004 06:52 AM
Bi-amping and power supply elco's edm Solid State 5 15th February 2003 04:45 AM
Page generated in 0.08160 seconds (75.89% PHP - 24.11% MySQL) with 10 queries
