Father, I abused my Leak S/20
Old 3rd June 2007, 12:38 PM   #1
bulgin is offline bulgin  South Africa
Default Father, I abused my Leak S/20
Hi All
I have 2 setups in a smallish room where I do measurements on transducers. There are 2 sets of speakers (the second pair often doing duty as computer speakers) and for them I use dedicated runs of speaker wire. The same speaker pair is also used with my Leak S/20 amp and another set of speaker cable is used for that. The two sets of cable runs are different types and different bananas are used for each pair of cables to avoid getting them mixed up.
There is also a Quad 405 MK1 in this room with its separate speaker cable pair, going to a second pair of standmount speakers and this setup stays like this permanently.
Both amps (the Leak and the Quad) share the same preamp, using rca adaptor plugs. Obviously only one amp is switched on at any given time.
Well, you know how it is...I had some spare time last night and took out my little Leak Point One Stereo pre-amp last night. It has been refurbished and revalved some years ago but hardly used. At the time of refurbishment, I also made up a 6-wire interconnect and for some stupid reason or other, I made it much too short for convenient use.
So, craving a bit of nostalgia for an all-tube kick, I carefully remade another 6-wire interconnect which goes between the Point One and the S/20.
It got too late last night and I tried it this morning....and nooo sound.
After a lot of checking, I decided to call it a day, convinced that the S/20 had somehow developed a problem.
A few minutes ago, I decided to have another look and found nothing wrong when I tried the amp with my usual s/s pre. Still no sound, until I looked at the speaker cables used for the Leak.
The speakers were wired for my computer setup...very stupid - no speakers, no sound.
Can anyone tell me how much damage can occur when an amp is switched-on with no speaker load? It was only for about less than 30 seconds.
bulgin
Old 3rd June 2007, 01:20 PM   #2
Klimon is offline Klimon  Belgium
Most tube-amps aren't damaged at all by this. If there is any danger, it's that the output transformers would get destroyed, which seems an issue with e.g. Decware zen-amps. None of the tube-amps I've built or owned had a problem when operated without speakers.
What makes most tube-amps immune and some prone to damage is something I'ld also like to know.
Simon
Old 3rd June 2007, 02:14 PM   #3
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
None at all.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 3rd June 2007, 02:25 PM   #4
Default Father, I abused my...
Thanks Guys
I'm listening to it now All is well.
bulgin
Old 3rd June 2007, 03:56 PM   #5
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
Driving an amp into clipping with no load will create some HUGE voltage spikes that can arc over the output transformer. Without overloading it, there isn't much danger.
A few amps will oscillate without a load, but not many - for instance one console amp I had (a console would always have speakers connected). But oscillation won't necessarily damage anything.
Old 3rd June 2007, 09:28 PM   #6
ray_moth is offline ray_moth  Indonesia
ray_moth's Avatar
You may have the resistors in the NFB loop to thank for that.
Old 3rd June 2007, 10:04 PM   #7
Johan Potgieter is offline Johan Potgieter  South Africa
To stick my neck out: Insufficient design, Simon. (But it could also be that the "immune" amplifiers are so over-compensated that there is little NFB left at high frequencies.)
But nobody used Zobel-networks back then; I do not know why not. Or one can do what Walker did in Quad: Make the feedback resistors low enough to act as a high resistance load but sufficient to prevent a complete open circuit - this is of value especially with pentode output stages. E.g. if the loudspeaker impedance is 8 ohms, you will only loose a few % of maximum output by terminating with say 470 - 560 ohms, and for convenience that could be the NFB network. It also cuts down on the effect of stray capacitances. Many amplifiers came with a 1K resistor on the output for the then 15 ohm loads.
Old 4th June 2007, 05:15 PM   #8
EC8010's Avatar
But that's two simultaneous fault scenarios, input overload and no output load. If the loudspeaker were to be connected, then you'd be looking for new tweeters.
Exactly.
Father, I abused my Leak S/20Hide this!Advertise here!
Happy Father's day Cal Weldon The Lounge 6 15th June 2008 10:24 PM
Most abused Lambda woofer and horn? nickmckinney Multi-Way 4 29th May 2008 01:12 PM
Please help me build an amp for my father anthonyl Tubes / Valves 25 23rd October 2007 01:25 AM
Almost repaired...but not yet...help a poor father bramdo Digital Source 4 30th January 2007 09:43 PM
Father & Son project almost ready, XO help needed AllCaster Multi-Way 2 4th December 2004 03:18 PM
