| diyAudio Sponsor | ||
I got a pair of 6688/E180Fs, a transformer with 190-0-190, 50V tap, and 3.15-0-3.15, 2 120H 36mA plate chokes and a used Hammond aluminium chassis. Can I put together a nice sounding line stage out of this without much extra cost?
If so, suggestions on operating conditions please? I can't seem to find its triode curves anywhere... that is if triode connection are the way to go if I read correctly... Also is this a lot of gain for a line stage? cheers! |
#2 | |
it will be too much gain,even in triode- if I remember correctly- in range of 40 to 60; you have two ways to do this- anode follower with choke load or-even better- WOT stage,parafeed or not. btw -awesome toob....... no!! dreky toob,send that to me for proper disposal !
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
I have a 6688 grounded grid line stage for my DAC. The DAC I got from diyparadise.com and the 6688 circuit was also featured on that website.
I think my voltages are close to the power transformer that you have. These linestage sounds very, very good. |
#4 |
I have my headphone amp running 6688's right now. They are quite nice -- more detailed than 5842's, but less full sounding perhaps. I have some 7788's on the way to try too.
Search is failing me, but here are some curves that were posted when I asked the same question a while back.
http://www.ecpaudio.com |
#5 |
The problems with the 6688 is the bias: grid current begins at -1,3 Volts, so the max. input signal is limited.
Andreas |
#6 |
Zen Mod,
I'm probably going to do it anode follower with choke loading. Don;t think I want to spend on OPT at this point of time. Any nice operating points to recommend? Alexg, I know you are using it for DAC, but have you compared GG vs anode follower for line-stage? AndreasS, Thanks for the reminder, should be sufficient for regular 2V output from CDP, phono right? |
#7 | |
But I would be very interested on the result of what you will be doing, for I have some 6688 tubes and would like to experiment with them. |
#8 |
How about a mu-follower, using the pentode as CCS??
/Magnus
#9 | |
Andreas |
#10 |
If you don`t need gain,,, a choke loaded cathodefollower?
http://www.tubecad.com/2007/04/blog0104.htm
Note to myself: Never again use fingers to check if there still is voltage left in a capacitor... |
| Aikido line stage - plus phono line stage | cjkpkg | Tubes / Valves | 1 | 22nd November 2008 09:50 PM |
| Help with e180f and ixys current reg | duderduderini | Tubes / Valves | 4 | 20th February 2008 12:51 AM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| E180F triode-strapped. | jim | Tubes / Valves | 15 | 16th September 2003 11:00 AM |
| Page generated in 0.10712 seconds (78.11% PHP - 21.89% MySQL) with 11 queries |
