| diyAudio Sponsor | ||
Say you are biamping. Your first amp has 2 capacitively coupled stages, the output would be 180 degrees from the input. The second has three capacitively coupled stages, the output would be 360 degrees from input. Will this be audible?
#2 |
I don't think capacitors introduce much phase shift at all away from the region they roll off
#3 |
What exactly is the problem ?
The effect of the 180° phase shift of the Anode/Collector/Drain Follower or the phase shift effect of a capacitor ? forget aboutr the last one. A few µm of inbalance in the paralleling of the Speaker coils will have a greater effekt.
Терпенье и труд все перетрут
| biamping and crossovers | Zorac | Multi-Way | 16 | 22nd December 2008 02:57 AM |
| Biamping silliness | suzyj | Solid State | 2 | 16th July 2007 03:53 PM |
| Zen-biamping | ijomojo | Pass Labs | 2 | 28th July 2005 08:01 AM |
| biamping questions | till | Multi-Way | 4 | 29th June 2004 11:57 AM |
| Turning a 2 way into a 3 way with biamping | Kanga | Multi-Way | 26 | 7th June 2003 10:52 AM |
| Page generated in 0.05848 seconds (72.74% PHP - 27.26% MySQL) with 10 queries |
