plate load ccs ala gary p question
Old 30th May 2007, 04:48 PM   #1
lt_texan is offline lt_texan  United States
Default plate load ccs ala gary p question
I loaded the first stage of my phonostage with a cascode ccs based on gary's doa site.
Funny thing is the battery biasing the base of the lower transistor goes flat after a while (long while measured in days)
With the phonostage not powered up, I can measure voltage across the sensing resistor and I calculate a drain of 0.9mA which is what the ccs was designed to pass.
Does this make sense?
Dan
Old 31st May 2007, 05:32 PM   #2
kevinkr's Avatar
As long as there is a path for current to flow the battery will go flat over time. The implication here is that before it does the operation of the ccs may be affected.
I don't have the schematic since the site seems to be gone now, perhaps you can post it if not in violation of copyright.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
plate load ccs ala gary p questionHide this!Advertise here!
Output trans plate load question 5687 vs 5965 phrarod Tubes / Valves 0 7th June 2009 03:24 AM
Plate load resistor question Carlp Tubes / Valves 14 21st January 2008 02:41 PM
CCS Plate Load Jack Thomas Tubes / Valves 4 21st May 2007 11:39 PM
bypassing the plate-load memphissound Tubes / Valves 3 12th December 2006 01:46 PM
Noob question about plate load eforer Tubes / Valves 14 23rd May 2006 06:24 AM
Copyright ©1999-2017 diyAudio
