any example of SE designs using GM70?
Old 30th May 2007, 01:42 AM   #1
jarthel is offline jarthel  Australia
Default any example of SE designs using GM70?
I've seen some designs (posted by fedgrove and the DRD GM70) but I believe they use interstage. the less transformer, the cheaper the project
thank you.
Old 30th May 2007, 09:18 AM   #2
aroS3 is offline aroS3  Greece
Send a message via MSN to aroS3
Gm70 Boatanchors Yahoo forum - A lot of info's
To take some ideas......
Old 31st May 2007, 07:51 AM   #3
Hojvaelde is offline Hojvaelde  Denmark
This is a group.
Have contacted the group with no responce return
Benny
Old 31st May 2007, 08:10 AM   #4
Gm70 Yahoo Group - Files Section
Take a look at the files section....
any example of SE designs using GM70?Hide this!Advertise here!
GU-50, GM70 and KT88 nina Tubes / Valves 55 19th February 2017 11:16 AM
want to do PP-GM70 day Tubes / Valves 79 10th October 2011 06:30 PM
GM70/GM70 parafeed SET? louischia Tubes / Valves 10 4th December 2008 03:12 PM
Another Gm70 amp !! HFGuy Tubes / Valves 4 8th July 2005 08:41 PM
GM70 Triode finwbu Swap Meet 12 21st January 2004 09:27 PM
