diyAudio Sponsor
Old 29th May 2007, 10:48 PM   #1
Sir Trefor's Avatar
Exclamation Replacing multi-section caps with multiple caps?
Is there any penalty or significant alteration in perfomance in replacing a bad can-type multi-section electrolytic with multiple caps of the corresponding multiple values, and wiring them in such a way such as to mimic the single cap?
I am curious, as our reserves of obsolete, NOS multi-sections are dwindling.
"This is just my 'one cent'; I haven't got two to give."
Old 29th May 2007, 11:17 PM   #2
Klimon is offline Klimon  Belgium
I think you can only expect improvement by using newer production (lower ESR etc.) separate electrolytics. For current production multi-section types for tube-gear see JJ electronics and Fisher&Tausche.
Simon
Replacing old caps in the SP8 pre-amp enilsen Tubes / Valves 6 7th February 2010 08:02 PM
Replacing the caps in the crossovers... dewdrop Multi-Way 13 22nd February 2006 12:56 AM
Replacing Caps on X-CD88 audioferret Parts 0 1st November 2005 08:06 AM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 02:02 PM
Page generated in 0.07587 seconds (71.36% PHP - 28.64% MySQL) with 10 queries
