| diyAudio Sponsor | ||
I've got some old radio transformers which I thought to use for another project, but I'm not sure it won't blow.
The PT is telefunken with 250V secondary (no CT) which should deliver about 290V B+. The total B+ current in the radio should have been around 180mA. It was a PP EL84. And then I have a PP output transformer from Siemens radio which looks relatively beefy and was used in another EL84 PP. May I use it for 6L6 PP amplifier? I believe the Siemens amplifier wasn't a 18W but rather around 15W (it wasn't a guitar one) and 6L6 under the above mentioned voltages may deliver around 20W class A with 2% distortion. |
#2 | |
Finally, "old radio transformers" weren't all that good, so I wouldn't expect good performance there either. |
#3 |
Might make a decent guitar amp though, right?
#4 | |
Most datasheets specify 5000 plate to plate load for 6L6 under 300V. Do I miss something? |
#5 |
diyAudio Moderator Emeritus
EL84 PP is supposed to have 8k p-p in Class AB1 PP pentode-mode. 6L6 needs 9k p-p for Class A in PP pentode-mode with 360v plate voltage and 270v screen voltage, or 8k p-p for Class A in PP triode-mode with 325v plate & screen voltage.
So, the impedance of your OPTs seems to be in the ball-park. What might be a problem, though, is the primary current demanded by the 6L6s, which may be significantly more than the EL84s and could cause overheating of the OPT primary windings. |
#6 | |
If you can stand a higher THD, then you can find an operating more in line with the OPts you mentioned, if you can run them at less than max power and they can withstand the current demand. |
#7 |
If I'm going to take the above mentioned PT with 250V secondary I won't get 360V for the plates. It seems to be more appropriate to aim at 270-280V plates and screens. Duncan Amps page says it's 270-270V with 72.5mA for plates and 8.5mA screens, 125 shared cathode resistor into 5,000 load. The result is 18.5W with 4.0 THD. Everything seems okay except for the currents and that's what I'm worried about.
Of course, less distortion is better but still 4% is much cleaner than 10% with EL84. |
#8 |
Go for it! The distortion will be much lower at your normal listening level. (4% just before clipping isn't bad at all).
I have made a bunch of amps with improper transformers and much too low voltages, and of course the tube is not working at full potential, but the results are often surprisingly good. |
#9 |
One way to get a little more plate voltage is to sneak in some negative voltage and use fixed bias. You may do so with an AC coupled rectifier to get the negaitve voltage if you are using a fullwave rectifier for the B+. Or you could use a couple (or three) 9volt batteries in series for the bias voltage.
| EF86 - Interstage transformer - EL84 PP AB | Joao Pedro | Tubes / Valves | 9 | 10th January 2009 05:46 PM |
| SE EL84 output stage? | Lingwendil | Tubes / Valves | 2 | 29th June 2008 05:55 PM |
| OPT resistance for EL84 PP Class A | pengboon | Tubes / Valves | 11 | 27th January 2006 06:52 PM |
| Class D high frequency output transformer | Bazukaz | Class D | 1 | 21st January 2006 03:24 AM |
| cheapest output transformer for a SE EL84 guitar | tschrama | Tubes / Valves | 12 | 23rd December 2003 10:15 PM |
| Page generated in 0.10079 seconds (86.34% PHP - 13.66% MySQL) with 10 queries |
