| diyAudio Sponsor | ||
Can any body tell me how long a Jensen PIO take to burn in.
Thanks |
#2 | |
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 | |
If you're talking about normal use, any capacitor polarizes within a few seconds. "Burn in" is just some audiophool myth, if not an outright marketing scam. If the latter, "burn in" lasts just as long as it takes to convince yourself that some uber-expensive thingamabob you bought actually makes a difference in how something sounds. |
#4 | |
A while back I did a listening test between Russian silver-mica caps (parallelled) and pio to choose the best coupling cap; one cap variety per channel. At first differences were subtle but after a few hours of play the sound between both was totally different: the pio's sounded really smooth while the mica's retained the harsh character both had at the beginning of the test... Either Russian silver-micas need very long burn-in or don't benefit from it at all, pio's improve dramatically after some hours. Regards, Simon |
#5 | |
However, you are right and sometimes when people sit comfortably, relax, switch on a nice looking amplifier... They relax and listen to the music hearing all details. You hear transformers, tubes, resistors, capacitors, even wires... Wires connect transformers, capacitors, resistors, tubes... Silver mica capacitors... Nice... Actually Russian silver micas have very fast burn-in, they burn-in instantly so you don't hear differences waiting long. As soon as you switch them on they already sound decently! The same very short time is for Russian Teflon (Ftoroplast-IV) capacitors. They burn in instantly and sound decent. Russian military could not afford long burn-ins so they always ordered fast capacitors, resistors, and tubes. But remember that they are fair! If some carbon comp or similar resistors sound harsh you will hear that harshness through Russian micas like you see through a pristine clean glass like a fresh clean water! So, you hear transformers... tubes... capacitors... resistors... You hear everything! You've switched it on...You relax, sitting comfortably, listening to the music... Your amp looks nice! You are absolutely right!
#6 |
I use Jensen PIO, Auricap, Multicap RTX, and Mundorf Silver in my amps. Having said that, I have not really cared about "burn in" as there is immediate audible differences between them but nothing that was reported by some where they sound bad then sounds awesome in a couple of hundred hours of play.
#7 | |
Neither the Russian military nor the US military would have recognized the kind of subtle "burn-in" issues being debated here, at least not for the general use of caps that they needed. Take it from a guy who designed a lot of radio and aerospace gear for various US agencies. And what's a "fast" cap or "fast" resistor? I've never seen a spec sheet for passive parts that had a "speed" parameter.
Brian |
#8 | |
Brian; for more info on the topic: http://nlp.snowseed.com/intro_inductions.htm ![]() (search for the Triple Spiral of Milton Erickson)
#9 |
I don't even know what a PIO is, and don't believe in burn-in for most things, but here are some facts. If you put a microamp meter on an electrolytic cap, you'll see high leakage when it's first powered up. The leakage will go down over minutes and hours, and might not reach it's ultimate low level for days or even longer. Audible? I can't say, but change, albeit small, is occurring.
Ceramic caps, especially with high dielectric constants, are subject to aging and poling effects, not to mention temperature. Hopefully you don't use them in the signal path, but they too will change over time. Let's not even mention tubes. One would never choose a Teflon capacitor as a standard for capacitance. Low dissipation factor maybe, if an air cap wouldn't do the job, but not capacitance. Why? Teflon can't be used in most structural applications because it flows. It isn't mechanically stable. Chances are, though I don't have documented proof of this, that the capacitance value would drift over the years. Standards are invariably made of very rigid materials. If you look on a fine enough scale, nothing is perfectly stable and changes tend to happen fastest when a part is first put into service. For sanity's sake however, one needs to grasp that below a certain level, these things really are inaudible. As implied above, it's way too easy to fool yourself into hearing or not hearing the nonexistent. |
#10 | ||
| Capacitor Burn-In/Break-In | serengetiplains | Parts | 48 | 20th November 2011 07:45 AM |
| Why burn in? | sianturi | Multi-Way | 17 | 1st January 2010 11:22 PM |
| JENSEN multi-tap capacitor | redrabbit | Parts | 3 | 10th April 2008 09:36 AM |
| Page generated in 0.12340 seconds (88.94% PHP - 11.06% MySQL) with 11 queries |
