| diyAudio Sponsor | ||
hey,
I have got a sta35 valve amp with one burnt sokket for el84 and one exploded chip. I want to fixs this amp and are desperat too find out what type of chip that should been there. are there anyone out there that know the name of this chip?? or have a schematics or a parts list or somthing? I would be greatful for any help.. |
#2 |
Hi e-mos,
Your are talking about a Dynaco? Can you post a picture of the damaged part? -Chris
"Just because you can, doesn't mean you should" © my Wife |
#3 |
While on the tube subject i found this = http://www.chambonino.com/construct/const3.html http://www.chambonino.com/construct/const10.html
#4 |
I believe (with the assistance of Google) that Woodside Electronics was formed after Arthur Radford retired in 1989.
The Woodside STA-35 is based on the Radford STA25 circuit but incorporated improved power transformer, power supply components and general component quality. The Radford STA25 and STA25R diagrams can be found here: http://www.ampslab.com/vintage1.htm Other info on of STA25 (without any chips): http://www.walther-mathieu.de/PROJEC...luckyfind.html http://www.audio-muziek.nl/audio/aud...radfordsta.htm Hope this may help. (they are however EL34 / 6550, and not EL84) Svein. |
#5 |
Hi Svein,
Thanks! I just learned something here. Never heard of Woodside before. -Chris
#6 |
hi svein
thnx for the info.. this helped me alot.. i have already fixed the burnt out part.. and now i am waiting for som parts inclusive some new tubs/valves.. the problems in my ampmost likly started in the power supply. i found a defective tantalium condenser to the power (78l05) to the exploded part. yes as you said the schematics of the radford sta-25r amp are very much the same with a few mods. it looks like sta35 have sepert power supplys for its channel In the power in the sta-25 there are a lm393 dual comparator op amp how ever in the sta-35 amp there are a bigger ic and this one are most likly a lm339 or simeler (correct me if i'm wrong) and are a quad comparator op amp. also i noticed that in my amp there are different tubes then what the sta25 uses. my amp there are used ecc81 as input and a ecc82 as driver and el84 as output. ecc81 and 82 are dual triodes and from the schematics of the sta25 there are used an ecc88 as input (dual triode) and 6ua8 as driver (seems too be a pentode and a triode?) also kt88 or 6550 as output. anybody that knows why??? any way as said i have fixed one channel of the sta35 and it is working.... it is working with one 12at7(ecc81), one ecc82 and two el84.. (if this is wrong plz let me know) pictures are coming soon.. |
#7 |
my bad... there are no el84.... they are el34....
#8 |
Hello, do you still have this amp?
I'm interested. Regards, Alex. |
#9 |
hello alex,
yes I still got the amp, have been very busy the last couple of months. So I haven't been able to post any pictures, yet. but i will take some pictures of the amp and post them later to day. |
#10 |
Hello, I'm interested in buying.
Can we discuss? Please let me know. Many Thanks, Alex |
| Swap Shanling CD-T80 valve CD player for Quad valve equiment | johnm | Swap Meet | 2 | 24th September 2009 12:15 PM |
| IRFP064 gets burnt | xyz9915 | Power Supplies | 30 | 5th February 2009 02:57 AM |
| Sub burnt bad. Garbage? | Miedosoracing | Subwoofers | 4 | 27th April 2006 01:59 PM |
| Convert a non-valve amp to a Valve (tube) Amp | seanthomas46 | Tubes / Valves | 11 | 6th September 2005 09:52 PM |
| burnt transformer | A'af | Digital Source | 1 | 20th May 2005 11:23 PM |
| Page generated in 0.10105 seconds (77.88% PHP - 22.12% MySQL) with 11 queries |
